1992 civic hatch rear end problem. any help appreciated
Old Jul 3, 2007 | 08:41 PM
drift2004's Avatar
Default 1992 civic hatch rear end problem. any help appreciated
hey i hope you guys can help me out, i have a 92 civic eg, i swaped out the entire rear assembly from a 91 integra. to conver tto disc brakes, everything fit, but the the rear end sits high, i wonder why? about a 5 finger gap and i have lowering springs and nothing, i can not find any info. i even used the civic lower control arm and nothing
Old Jul 6, 2007 | 06:58 AM
92_civic's Avatar
Default Re: 1992 civic hatch rear end problem. any help appreciated (drift2004)
did you swap over the shocks and springs too? if so that is your problem...take the disc brake parts off the teg trailing arm and put them onto your civic arm and use the civic lower control arm, trailing arm, and spring and shock
da's have diff rear suspension than an eg, what I am trying to say is that you should only use the disc brake parts from the teg, not the arms and shocks
Jr209
Mar 27, 2018 11:55 AM
andyfee
Jul 29, 2008 08:38 AM
serb_rida
Suspension & Brakes
Jun 19, 2008 04:16 PM
eg6madness
26
Aug 12, 2007 10:26 AM
handiman15
26
Apr 13, 2002 01:11 AM
