AC Compressor not getting signal to kick on, but works when hardwired
Old Jul 3, 2007 | 03:33 PM
superfuji57's Avatar
Default AC Compressor not getting signal to kick on, but works when hardwired
Recently reinstalled my AC system. The compressor does grab when turned on, but when I hard wire it it does and blows cold air. At the harness directly going to the compressor it's not getting any positive signal, what are my possible fixes? I've already checked the fuse. TIA
Old Jul 3, 2007 | 05:06 PM
RenegadeB20's Avatar
Default Re: AC Compressor not getting signal to kick on, but works when hardwired (superfuji57)
hard wire it how??? it the r134a is low the pressure switch wont turn the compresser on
Old Jul 3, 2007 | 05:14 PM
It was the relay :up:
Old Jul 14, 2007 | 04:52 PM
Darve's Avatar
Where is the relay located. I've "Hardwired" the compressor to and it has kicked on but it doesn't have power through the harness.
Old Jul 14, 2007 | 05:38 PM
MatterMatt's Avatar
Default Re: (Darve)
The relay is in the underhood fuse box. You have to check for power to the compressor with the car running. Don't hardwire AC compressors. You'll end up junking your compressor and or clutch.
Zak Greenwell
16
Feb 16, 2023 01:05 PM
thisguyaves
Honda Civic (2001 - 2005)
Jun 3, 2018 01:47 PM
saikou
Aug 9, 2011 08:22 PM
blewispunk
19
Jun 24, 2009 07:31 AM
hmtcrxsir
22
Jul 25, 2008 03:19 PM
