spiking idle?
this just started, but when i come to a stop the car will idle at like 1500 or so and stay there, then drop to the normal 900 or so. what would cause this? should i be worried?
Car wouldnt happen to be tuned or anything would it... or is it just stock. Idle air control valve is supposed to keep your idle from fluctuating like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">Car wouldnt happen to be tuned or anything would it... or is it just stock. Idle air control valve is supposed to keep your idle from fluctuating like that.</TD></TR></TABLE>
its a LS/VTEC with very minor work done...headers, intake, etc.....
You didn't by chance swap the trans at the same time as the lsv, did you? Because I had that problem on my turbo lsv going from auto to manual at the same time, and it was because that needs an iacv swap for the manual trans..
Junkyard2000
Oct 26, 2005 03:16 PM
