whos used 92-95 civic shocks on there 96-00 civic???
Old Jul 3, 2007 | 03:12 PM
bmoua's Avatar
Default whos used 92-95 civic shocks on there 96-00 civic???
i know eg shocks bolt right up to 96-00 civics but i wanted to know if the people whos done this was satisfied with the outcome??
Old Jul 3, 2007 | 03:45 PM
BlueIntegraBoy's Avatar
Default Re: whos used 92-95 civic shocks on there 96-00 civic??? (bmoua)
I'm sure lots of people because Tokicos are like your Sk2s, using rear washers. That means same valving.
Old Jul 3, 2007 | 03:47 PM
97Ej6mike's Avatar
The rear strut forks required a diff bolt when i bought my friends used tokicos off his ej1 for my ej6. Thats the only issue we ran into.
Old Jul 3, 2007 | 03:51 PM
bmoua's Avatar
i might be picking up a set of eg kyb agx's for my ej8 so i just wanted to make sure they were vavled somewhat the same. i know the part numbers for the eg and ej8 application is different though. When i had my old agx's my GC's fit perfectly tight on the shocks. But on the eg shocks my gc's fit loosely which i know isn't a problem becuz once the car is off the jack the pressure will hold it steady.
Old Jul 3, 2007 | 09:45 PM
bmoua's Avatar
anybody else?
Old Jul 3, 2007 | 10:35 PM
pkdog167's Avatar
Default Re: (bmoua)
my bro have a set of 92-95 shocks on his 96 civic, you need washer or tighten the bolts for the rear shocks.
Old Jul 3, 2007 | 10:41 PM
bmoua's Avatar
Default Re: (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">my bro have a set of 92-95 shocks on his 96 civic, you need washer or tighten the bolts for the rear shocks.</TD></TR></TABLE>
what kind of shocks were these? how long did they last? did he like the outcome?
Old Jul 4, 2007 | 12:31 AM
pfourtythree's Avatar
Default Re: (bmoua)
I haven't ever tried to use 92-95 shocks in an 96-00 personally, but a buddy of mine swapped his gc coilovers from his old del sol into a 98 ek and he said they were fine for the first 5k or so, but now they rattle like a mo fo, i dont know if its because the struts are shot or what, but just from that it doesn't seem like a good idea.
but like i said before, they were used coils, so that might be why they are fcuked...
Old Jul 4, 2007 | 10:39 PM
pkdog167's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
what kind of shocks were these? how long did they last? did he like the outcome?</TD></TR></TABLE>
He put a tokico white in there and it just works like what it should be.
Old Jul 5, 2007 | 03:59 AM
RyanA's Avatar
I just got done putting the struts off of an EG on my 98 4 door. Only difference up front is the EG has the mounts for the brake lines whereas the 96-00 doesn't use them. Rears, just use a couple washers to take up the slack. Fit great, work great...
Ryan
Old Jul 5, 2007 | 11:21 AM
projectpd's Avatar
Default Re: (RyanA)
i tought you couldent use 92-95 civic rear shocks on 96-00 cuz of the lower part on the shock isent long enough ! like from the shock to the bolt isent long enough for the control arm ! is this true ? havent had the time to check it ! let me know thanks boys !
Old Jul 5, 2007 | 11:24 AM
speedooo's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">The rear strut forks required a diff bolt when i bought my friends used tokicos off his ej1 for my ej6. Thats the only issue we ran into.</TD></TR></TABLE>
wrong. the bushing in eg's is wider than an ek bushing, so the strut will have some play in it, just throw a couple washers in there and youll be fine
Old Jul 5, 2007 | 11:38 AM
projectpd's Avatar
Default Re: (speedooo)
my buddy has a 1992 civic dx 4door would those rear shocks fit on a my 1997 civic ex 4dr ! would they ?
Old Jul 5, 2007 | 11:49 AM
Jizzmaster Zero's Avatar
(banned)
Default Re: (projectpd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectpd &raquo;</TD></TR><TR><TD CLASS="quote">my buddy has a 1992 civic dx 4door would those rear shocks fit on a my 1997 civic ex 4dr ! would they ?</TD></TR></TABLE>
Yes:
The only difference on the rears is that '96-'00 LCA is thinner, so you need washers to fill in the gap. Nothing else is required.
I still have the washers that came with my Tokico rears (I have a 92) if anybody needs them for an EK install.
Old Jul 5, 2007 | 01:08 PM
VAAJ's Avatar
Default Re: (Jizzmaster Zero)
****, so thats what the washer are for. I didn't even use the washer, just force the bolt in until its tight.
Old Jul 5, 2007 | 03:49 PM
bmoua's Avatar
Default Re: (VAAJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VAAJ &raquo;</TD></TR><TR><TD CLASS="quote">****, so thats what the washer are for. I didn't even use the washer, just force the bolt in until its tight.</TD></TR></TABLE>
haha make sure you use washers bro,
anybody else??
haze808
Suspension & Brakes
Nov 15, 2010 12:32 PM
PearlWhiteAccord
Jan 18, 2007 06:24 AM
PearlWhiteAccord
Suspension & Brakes
Jan 17, 2007 06:59 PM
RACEPAK
12
Apr 17, 2006 04:34 PM
sooo_slow
Oct 12, 2005 05:07 PM
