Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Pioneer AVIC-D3 receiver
Old Jul 3, 2007 | 12:32 PM
chiggin's Avatar
Default Pioneer AVIC-D3 receiver
I am thinking about purchasing the pioneer AVIC-D3 receiver for my '07 Si coupe. I did not get the honda nav system so I know I will have to get the double din dash panel to install the pioneer deck. Has anyone installed an aftermarket in-dash nav unit? How well does it work out? Is there somewhere I can purchase the double din panel other than ebay? Is there a way to link the steering wheel controls to the new receiver so that they can still be used? Can the deck be set up so that it will play video while the car is in motion? I know that's a lot of questions, but I've never installed an aftermarket stereo in a car before (didn't think it worth it in my last car...'95 taurus with 265,000 miles). Any pics would be appreciated as well.
Old Jul 3, 2007 | 12:46 PM
IT GUY's Avatar
Default Re: Pioneer AVIC-D3 receiver (chiggin)
http://www.crutchfield.com/S-O...VICD3
click on installation details...
or
just go here...
http://www.crutchfield.com/S-O...1561B
a few guys here use aftermarket NAV and I think someone even uses the pioneer you're looking at.. I'm sure somone can chime in with more info
"and you also have the option of wiring the AVIC-D3 into your steering wheel controls for a convenient, factory feel."
-from the product description
also from product description:
"Memory Navi Mode: When the DVD Map Disc is inserted, you can store the map data into the internal memory of the navigation system. If the map disc is removed, navigation is performed by using data in the memory. In the Memory Navi mode, you can play a music CD or DVD Video on the navigation system while navigating at the same time. Some functions are restricted in the Memory Navi mode, and you may need to reinsert the DVD Map Disc to use those functions"
so you should be able to use steering wheel controls and watch DVDs even while navigating from saved data
Old Jul 5, 2007 | 09:07 AM
gunmetalej's Avatar
Default Re: Pioneer AVIC-D3 receiver (IT GUY)
go to honda they sell the double din dash kit used for the factory navi there. you will be able to install the D3 using it and it will look better than those cheap plastic kits. its around 100 bucks but its worth it. it also comes with metal mounting hardware and not plastic.
Old Jul 5, 2007 | 09:09 AM
Type X's Avatar
Default Re: Pioneer AVIC-D3 receiver (gunmetalej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunmetalej &raquo;</TD></TR><TR><TD CLASS="quote">go to honda they sell the double din dash kit used for the factory navi there. you will be able to install the D3 using it and it will look better than those cheap plastic kits. its around 100 bucks but its worth it. it also comes with metal mounting hardware and not plastic. </TD></TR></TABLE>
The honda double din oem dash trim is about 48 dollars online.
Old Jul 5, 2007 | 09:51 AM
chiggin's Avatar
Default Re: Pioneer AVIC-D3 receiver (Type X)
Thanks for the info so far. I can't believe I forgot about Crutchfield. Where on the Honda website do I need to go to find the double din oem dash trim?
Old Jul 5, 2007 | 10:49 AM
IT GUY's Avatar
Try here for the OEM double din dash:
http://www.hondaautomotivepart...DE%29
Old Jul 5, 2007 | 10:36 PM
DynastyRacer22's Avatar
http://shop4.outpost.com/produ...LT_PG
thats what your going to need after you install the pioneer d3 into your car if you wanna use the steering wheel control..1 of my co worker bought the same indash and had to get the Peripheral oem steering wheel control
i work at frys electronics thats how i found out
Old Jul 5, 2007 | 11:19 PM
gunmetalej's Avatar
Default Re: (DynastyRacer22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">
The honda double din oem dash trim is about 48 dollars online.</TD></TR></TABLE>
thats even better i need one!
Old Jul 6, 2007 | 04:41 AM
IT GUY's Avatar
Default Re: (gunmetalej)
$21.11 from majestic honda online
Old Jul 8, 2007 | 10:39 AM
B18civicsi00's Avatar
Default Re: (IT GUY)
I wouldnt get the D3 just for the fact when you are using the GPS portion of the system you need to use the GPS DVD.When you are using that you cant play a cd. I would get the AVIC-Z2. which has a built in 30 gig hard drive which you can download the GPS CD on so you can play cds at the same time.
Old Jul 8, 2007 | 12:05 PM
bbRedSi's Avatar
Default Re: (B18civicsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18civicsi00 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt get the D3 just for the fact when you are using the GPS portion of the system you need to use the GPS DVD.When you are using that you cant play a cd. I would get the AVIC-Z2. which has a built in 30 gig hard drive which you can download the GPS CD on so you can play cds at the same time.</TD></TR></TABLE>
yes but it also costs more than twice the amount of the D3
Old Jul 8, 2007 | 06:51 PM
JTaudio0212's Avatar
Hey dude, ok...
#1 Go to http://www.avic411.com which will tell you EVERYTHING to do with the D3 install (bypass, custom backgrounds, etc...)
#2 I put a D3 in my 07 Si 4dr. and I LOVE IT. It is definitly highly recommended.
#3 The whole thing about the D3 only having once disc slot for the Nav. disc and trying to listen to CD's or watch DVD's isn't that big of a deal if you have an I-Pod. You can watch all the videos on your I-Pod and the I-Pod software that pioneer made for the D3 is AMAZING.
#4 I have put in at least 15 D3's in many cars and my Si is definitly one of the best looking. The dash kit you can get from Scosche is really nice, the color match is perfect and overall fitting of the kit is flawless. (Not to mention the VSS is in the factory radio harness)
#5 If you shoot me your e-mail I will definitly send you some pics of the D3 installed... but in my opinion the D3 is an excellent choice
Old Jul 9, 2007 | 04:55 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
go read about the D3, I think you are misinformed about it's capabilities.
Old Jul 9, 2007 | 11:15 AM
yed's Avatar
yed
You must first set the route on the D3 and upon doing that you can remove the navigation disc and put something else in. If you want to change the route or do anything with it, you have to put the DVD back in.
Easiest solution is: http://www.pioneerelectronics.....html
Old Jul 9, 2007 | 11:39 AM
IT GUY's Avatar
Default Re: (yed)
by setting the route and removing the navigation disc, you are entering Memory Navi Mode... isn't that what I already posted about?
Old Jul 9, 2007 | 12:01 PM
nightryder21's Avatar
Look into the Kenwood DNX7100. Best of both worlds. No DVD needed for navigation and less expensive than the AVIC-Z2.
http://www.crutchfield.com/S-i...0#Tab
Old Jul 9, 2007 | 12:28 PM
IT GUY's Avatar
Default Re: Pioneer AVIC-D3 receiver (nightryder21)
it's still $400 more than the D3
Old Jul 9, 2007 | 01:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">it's still $400 more than the D3</TD></TR></TABLE>
And it comes with:
* Garmin Navigation
* Radio Data System
* USB Inputs (Plug in mp3 players, usb sticks, or a hard drive with all your music and videos)
* 2 A/V Inputs
* Wireless Remote
* SD Card Slot
* 6.95'' Screen
* JPEG & MPEG video Support
Old Jul 9, 2007 | 04:30 PM
yea... but its a kenwood
Old Jul 9, 2007 | 04:48 PM
chiggin's Avatar
Default Re: Pioneer AVIC-D3 receiver (JTaudio0212)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTaudio0212 &raquo;</TD></TR><TR><TD CLASS="quote">yea... but its a kenwood </TD></TR></TABLE>
^ lol, my thoughts exactly
Thanks for the info on the d3 jtaudio. I can't do the im thing yet to send my email since I'm still in 'trial mode'. I do want to see the installed pics though. I guess i'll either have to wait for the im thing to work, or you can im your email to me...either one will work.
Modified by chiggin at 9:02 PM 7/9/2007
Old Jul 9, 2007 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chiggin &raquo;</TD></TR><TR><TD CLASS="quote">
^ lol, my thoughts exactly</TD></TR></TABLE>
You guys guys should really do your research and stop being so ignorant.
Old Jul 9, 2007 | 05:05 PM
chiggin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightryder21 &raquo;</TD></TR><TR><TD CLASS="quote">You guys guys should really do your research and stop being so ignorant. </TD></TR></TABLE>
don't worry my friend, i already have. i have just never been a fan of kenwood. nothing against them, it's just personal preference.
Old Jul 9, 2007 | 05:38 PM
don't worry my friend, i already have. i have just never been a fan of kenwood. nothing against them, it's just personal preference.</TD></TR></TABLE>
Well if you really want a good Navi system don't rule this one out cause your not a "fan".
Old Jul 9, 2007 | 05:41 PM
lolumad's Avatar
YOU'RE ALL BEING IGNORANT
Old Jul 10, 2007 | 08:36 AM
Philip260's Avatar
Hey IT,
when i browsed for the panel on the side it provided two products with two color schemes:
UH GUN METALLIC
US TAUPE GUN METALLIC
Does anyone know the difference? I'm looking to get a factory navigation in my Royal Blue Civic Sedan LX and need the panel. Which one will match my current dashboard color or are they the same?
Thanks in advance.
