D series build questions
I've been doing some searching about a d16z build and i still have a few questions. I have only seen posts from people that already have their build together. My Eg is currently running a D16z6 with the following mods:
Short Ram Intake
Skunk2 Stage 1 Cam
4-1 Header
Apex World Sport exhaust
Magstar Wires and Platinum Plugs
Adjustable Cam Gear Skunk2 (not on car)
Valve Springs and Retainers Skunk2 (not on car)
I was hoping to make a high compression N/A build and was wondering if this was possible in a roundabout $500 budget including the mods i already have. Also I can't seem to find out if I'm going to need any tuning or aftermarket electronics. Finally, is a high compression D safe for daily driving?
Short Ram Intake
Skunk2 Stage 1 Cam
4-1 Header
If you do it the right way with quality parts and no ebay crap, probably not.
ARP head studs are around $125
OEM HG $50 plus bore
various seals, gaskets, etc
bearings
machine work
pistons
rod bolts
some sort of EMS
dyno time + tuning
Assuming the build and tune are good and you run it on the right gas, yes it will be safe for daily driving.
Without a good head and bigger cam, I wouldn't bother with higher compression. Not worth it to pay more for gas if the car isn't used for some type of racing IMO.
bearings
machine work
pistons
rod bolts
some sort of EMS
dyno time + tuning
jrodri1018
Nov 21, 2017 08:08 PM
xxjonxx4
Jul 23, 2017 11:22 AM
