Door Does Not Open
Old Jul 3, 2007 | 08:55 AM
HondamanXxX's Avatar
GO GIANTS!
Default Door Does Not Open
My gf has a 97 DX Coupe. The problem is is that the passenger door does not open.
In order to open the passenger door you have to open it from the outside by putting the key in, turn to the right, and while doing that lift up the handle and the door opens. You can not open the door from the inside. Any suggestions where I should start to try to fix this?
Very dangerous
Old Jul 3, 2007 | 09:00 AM
MJ0LNIR's Avatar
Default Re: Door Does Not Open (HondamanXxX)
Open the door and take off the interior door handle, then take off the interior trim panel. Check behind there and make sure all of your linkages are hooked up. My guess is that they aren't, or that they're bent or something. You might also want to pick up a different exterior door handle.
Old Jul 3, 2007 | 09:01 AM
GO GIANTS!
Default Re: Door Does Not Open (MJ0LNIR)
Hmm. I'll check that out. THanks
coloradod16
Nov 13, 2008 01:33 AM
pstanger
Aug 22, 2007 08:58 AM
blackflag188
Apr 26, 2004 12:23 PM
KidMo
Jan 15, 2003 12:06 PM
Mr. Softee
Jul 30, 2001 11:06 PM
