Integra ECU Pinouts
I am currently swapping a SiR Integra motor in my ls. Obviously my ls doesn't have vtec, so i am going to run the EVAP and IAB solenoids directly from the plugs in the motor to the ECU. I have done some research and found which pinouts to put the wires. My question is really which solenoid is the EVAP purge and which is the IAB. I know the what i am missing on my ls, i just don't know which is which. Does the EVAP purge solenoid look like small cylinder directly in front of the distributor? I have also heard that if you don't hook them up correctly, the motor will red-line at 6 grand. Is this true? Anyone with info. would be very helpful.
P.S. Please correct me if any of the current info. i hold as true is wrong. I want to do this right the first time.
hybrid1990crx
Aug 17, 2004 11:31 AM
