PCV to atmosphere
Anyone doing this? Seems like it would keep the engine bay cleaner and free of a catch can. I'm talking about leaving the stock PCV can in the back of the block and routing a hose from the top outlet to under the car. Cheapest and easiest way i think. Opinions?
I searched and there are 2 threads about it specifically. They are a couple years old, just wondering if anybody is doing this now?
I gutted my PCV valve and ran a hose from that to the ground, then I have a hose from my valve cover breather to the ground.
Works well! Cheap and easy.
That's what I'm doing, but instead of just going straight to the ground it goes to an empty brake fluid bottle. I have 2 bottles one for the valve cover and one for the block. Same concept, just catches oil instead of dripping it. Both of my bottles are bone dry still though *shrug*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">I gutted my PCV valve and ran a hose from that to the ground, then I have a hose from my valve cover breather to the ground.
Works well! Cheap and easy. </TD></TR></TABLE>
if you gutted the pcv wouldnt it suck in crap from the ground in vacuum and blow out boost while in boost? or am i not be gettin what you sayin?
The hose that connects from the PCV to the intake is being left open. Where the hose connected to the intake is closed off so there is no boost/vac going to the PCV hose
edit: ^^ you beat me to it LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec »</TD></TR><TR><TD CLASS="quote">^No, because it's no longer have a vacuum source. The vacuum source for the black box will be cap off from the intake manifold or use for other vacuum source. </TD></TR></TABLE>
Yup, I capped off the port on the IM where the PCV line used to be connected to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I never understood taking the time to gut the pcv valve. Why go through the trouble when You can just run a vac line off of the black box?</TD></TR></TABLE>
Honestly, I just don't like having to reach under my IM to connect it. lol That's it. If I had easier access to the black box then I would just run a line off that. I also had an extra PCV valve in my tool box that I used.
But yeah, same thing. If it's easy for you just go off the black box.
If putting just a line off the valve cover to dump somewhere, is that fittings diameter big enough to move the proper amounts of air in order to relieve enough pressure?
i went to home depot and bought a barb fitting and pressed into where my pcv used to be and put a baby k&n filter on it. it fits under my fuel rail. and i put anothe filter on the vc and it seems to be ok so far. my buddy is running the same on his 50 mile a day dd. no problems. good luck.
spock_rocker
13
May 29, 2004 11:36 AM
