Possible to install Apexi Worldsport II incorrectly?
Old Jul 3, 2007 | 05:44 AM
nutsack's Avatar
Default Possible to install Apexi Worldsport II incorrectly?
I installed a WS2 and when i torque down all the exhaust bolts the top of the muffler canister closest to the exhaust tip hits the chassis. I have it so the the part where it bolts to the cat is like this (x being the bolts and O being the exhaust piping)
X
X O X
Also the S-pipe only fits on one way correct?
Old Jul 3, 2007 | 05:53 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Possible to install Apexi Worldsport II incorrectly? (*******)
Can you loosen everything up and wiggle it around to get a better fit? I've had to do that on other cars before - bolt loosely and move around until everything lines up right.
Old Jul 3, 2007 | 05:55 AM
nutsack's Avatar
Default Re: Possible to install Apexi Worldsport II incorrectly? (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Can you loosen everything up and wiggle it around to get a better fit? I've had to do that on other cars before - bolt loosely and move around until everything lines up right.</TD></TR></TABLE>
i tried that, if i loosen the bolts it's fine. it's only when i torque down all the bolts that it rubs the chassis.
Old Jul 3, 2007 | 06:41 AM
hayabusa160's Avatar
if i remember right its possible to put that s bend pipe on back wards. because my friend did it once on his apexi n1.
ef dino
Oct 31, 2007 04:46 AM
RTW DC2R
Apr 29, 2004 12:08 PM
Jimmy
May 30, 2003 05:27 AM
steve_s
Apr 17, 2003 09:44 PM
GSRaCeRbOI
Jul 24, 2002 10:07 AM
