Main Relay
Old Jul 3, 2007 | 12:03 AM
Ep1dem1c's Avatar
Default Main Relay
I was wondering if my main relay was bad would my car try to turn over but just sit there and try?
I have a EG hatch with a B16 in it. thanks
there is no spark
Brand New:
Distributor, cap, coil, rotor, wires, spark plugs, fuse is good too
Old Jul 3, 2007 | 12:17 AM
BlueIntegraBoy's Avatar
Default Re: Main Relay (Ep1dem1c)
Bad main relay won't prime the fuel pump = no fuel
Old Jul 3, 2007 | 12:50 AM
alacard's Avatar
Turn your key to the 2nd position, and listen for a quiet electrical buzz coming from your passenger side dash area. If you hear that noise, your main relay is working.
Old Jul 3, 2007 | 06:49 AM
ICC_Texas's Avatar
you stated coil...
could also be your igniter... its the most expensive of the dizzy internals.
if your fuel pump is priming, then i'm putting my money on the igniter/ICM
C-RICKS
Aug 15, 2009 06:05 PM
Lb1atx
Aug 1, 2007 10:52 PM
wambus
Feb 12, 2004 08:40 PM
T-RO
Nov 7, 2003 03:30 PM
Caveman74
Aug 17, 2003 10:18 AM
