can i use a 96 gsr cluster......
Old Jul 2, 2007 | 10:40 PM
pundagreat's Avatar
Default can i use a 96 gsr cluster......
on a 98 ls integra????????????????? and why???????????????????/
Old Jul 2, 2007 | 11:14 PM
davidluko's Avatar
I'm pretty sure that 94-97 and 98-01 clusters are NOT interchangable. They'll plug in but it'll always pop a fuse, if I remember right.
Old Jul 2, 2007 | 11:20 PM
Force1stiptopped's Avatar
i think ur right Hatch
The 98-01 have certain little differences (such as the factory immobilizer that has an icon on the cluster)
Old Jul 3, 2007 | 12:20 AM
BlueIntegraBoy's Avatar
Default Re: (Hatch_R)
It won't pop a fuse. The fuel gauge, seatbelt light, and ABS lights are in different pins.
Old Jul 3, 2007 | 02:56 PM
vladd's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It won't pop a fuse. The fuel gauge, seatbelt light, and ABS lights are in different pins.</TD></TR></TABLE>
have you tried it? it will. i've seen someone try to put a 97 cluster into a 98, there was a certain fuse under the hood that kept popping. he finally realized that 94-97 and 98-01 aren't interchangeable and the problem with fuse went away. only 00-01 have the immobilizer btw.
Old Jul 3, 2007 | 03:23 PM
SkertySkerty's Avatar
i have a 99 gsr cluster in my 95 ls and everything works fine but the fuel gauge and a few other lights but the tach speedo odometer and **** works so i just took my fuel gauge out of my cluster and put it in the gsr cluster and it works fine!
Old Jul 3, 2007 | 03:24 PM
vladd's Avatar
Default Re: (SkertySkerty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty &raquo;</TD></TR><TR><TD CLASS="quote">i have a 99 gsr cluster in my 95 ls and everything works fine but the fuel gauge and a few other lights but the tach speedo odometer and **** works so i just took my fuel gauge out of my cluster and put it in the gsr cluster and it works fine!</TD></TR></TABLE>
the 95 has gray faces while the 99 has black. now you have a mismatched cluster. should've just got a 94-97 one.
Old Jul 3, 2007 | 03:28 PM
yeah your wrong everything is fine!
Old Jul 3, 2007 | 03:34 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkertySkerty &raquo;</TD></TR><TR><TD CLASS="quote">yeah your wrong everything is fine!</TD></TR></TABLE>
94-97 gauge clusters have gray faces. 98-01 have black. you have 3 black faces with 1 gray according to what you posted above.
Old Jul 3, 2007 | 03:36 PM
iunno i never noticed haha i'll go check it out later!
Old Jul 3, 2007 | 04:29 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
ur all wrong all 94-01 gauge clusters are the same and i put a 2000 gsr gauge cluster in my 94 gsr all u need to do is change the green film on back of the gauge cluster
Old Jul 3, 2007 | 09:47 PM
davidluko's Avatar
If you switch around the wiring our the circuits you might be able to make it work but that's a different story. And BTW DOHCgarage, the 94-97 are grey face while 98-01 are black like someone said so that alone is a difference. The black looks much better IMO.
Old Jul 4, 2007 | 02:00 AM
vladd's Avatar
Default Re: (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">ur all wrong all 94-01 gauge clusters are the same and i put a 2000 gsr gauge cluster in my 94 gsr all u need to do is change the green film on back of the gauge cluster</TD></TR></TABLE>
nope, i'm actually right. i've seen it done. you're right, you can modify the clusters to work in any car you want to; we're talking stock into stock. you had to modify the 98 to work in the 97, correct? an unmodified 98 cluster WILL NOT work properly in a 97.
Old Jul 6, 2007 | 10:30 PM
Default Re: (vladd)
no i ment i had a 94 gsr cluster and i threw in a 2000 gsr cluster at first the gauges went crazy so i changed the green film on the back of cluster and everything worked great no wires needed to be modified
Old Jul 6, 2007 | 10:34 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">no i ment i had a 94 gsr cluster and i threw in a 2000 gsr cluster at first the gauges went crazy so i changed the green film on the back of cluster and everything worked great no wires needed to be modified </TD></TR></TABLE>
i got what you meant; you had to modify the 00 cluster to work in the 94 properly. you said yourself the gauges went crazy when the cluster wasn't modified; therefore, they're not the same. if they were the same the 00 cluster wouldn't need to be modified.
Old Jul 6, 2007 | 10:50 PM
Default Re: (vladd)
whats so hard about switching the green film thats all i did to make it work perfect is that too hard??????
Old Jul 6, 2007 | 11:03 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">whats so hard about switching the green film thats all i did to make it work perfect is that too hard?????? </TD></TR></TABLE>
jesus christ, can you read?? you said that we're wrong; that all 94-01 clusters are the same. they are obviously not the same, as you've already said yourself. you said 2 different things; that they are the same, and that they're not. the 2nd part was correct, the first wasn't. it's not that complicated.
Old Aug 6, 2007 | 02:37 PM
93b16's Avatar
Default Re: (vladd)
calm down just because someone knows more than you does't mean you need to get all pissy. at least he knew what he was talking about. next time just be an *** from the start and just tell them to use the search button instead of crying like a baby.
Old Aug 6, 2007 | 03:13 PM
THE LORD OF CHAOS's Avatar
there are two ways to make the cluster work. one way is swapping the films. the other way is to dissassemble the clusters and swap the gauges out. there is a thread with a step by step process to do this somewhere.
Old Aug 6, 2007 | 04:20 PM
wegotmorrison's Avatar
Default Re: (THE LORD OF CHAOS)
Well regardless, why would you want gsr gauges in an ls?? You cant take your ls to 8... haha
Old Aug 6, 2007 | 05:22 PM
Default Re: (wegotmorrison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wegotmorrison &raquo;</TD></TR><TR><TD CLASS="quote">Well regardless, why would you want gsr gauges in an ls?? You cant take your ls to 8... haha</TD></TR></TABLE>
engine swap?
Old Aug 6, 2007 | 05:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE LORD OF CHAOS &raquo;</TD></TR><TR><TD CLASS="quote">
engine swap? </TD></TR></TABLE>
I hope so.. that would make more sense, yeah
Perez_cb7
Jul 23, 2013 10:32 AM
egb18crt
Apr 1, 2007 09:26 PM
enzozenuni
Dec 24, 2006 12:20 AM
3.point.2
14
Aug 8, 2005 10:23 AM
