ECU/Starting Problems..PLS LOOK.
Old Jul 2, 2007 | 09:55 PM
yanksox's Avatar
Default ECU/Starting Problems..PLS LOOK.
So I just completed my ls/vtec swap in my crx. I have a obd0 to obd1 jumper harness along with a chipped and socketed p28. The ecu works fine due to I just pulled it from a car a few minutes before putting in my crx. When the jumper harness and obd1 ecu is in it will not start. It turns over, sparks, and sends fuel. Now when I put my pr4 ecu in, direct plug in no jumper icluded it starts fine and runs fine. If anyone has any advice please let me know. Thanks
Old Jul 3, 2007 | 02:10 PM
99y8's Avatar
i just had this happen with my p28 in a '99 ex w/ b20 not too long ago... a couple things to check... make sure the jumper harness is undamaged from removal and installation... another problem could be the ECU... if you have another chip, try it and see if that solves the problem...
Old Jul 3, 2007 | 02:54 PM
yanksox's Avatar
Default Re: (99y8)
Tried all that and then swapped it to an obd1 distributor and still nothing.
Ls-v Da Teggy
Aug 5, 2013 11:27 PM
hondadw08
Feb 2, 2010 10:39 PM
sevenfc
Jul 23, 2009 05:57 PM
AnthraxVX
Feb 15, 2006 03:08 PM
