Coolant coming out of my clutch line?!
Ok WTF, just got back from the corner store, 5 minute drive, popped my hood to source my coolant leak that I can't find, and my clutch cable has a pinhole and its shooting fluid all over my engine bay; I pop the rad cap and it stops...
Whats going on?!
Modified by metal at 8:25 PM 7/2/2007
Whats going on?!
you should check the small hose next to your clucth cable because it is inposible for your clucth cable to leak coolant because it doesn't have any...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">that is very odd.
Weird
</TD></TR></TABLE> Weird
Looks like the small water line next to the yellow circle has some coolant on it as well. Check that, maybe it has a tiny pin hole and when pressurized it sprays onto its surroundings
The spot where I circled was where it was shooting out of lol. Thats why the intake piping and other surrounding stuff is wet, because it was shooting straight up. I watched it for about 5 seconds before I popped the rad cap, then it stopped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6civicturbo »</TD></TR><TR><TD CLASS="quote">you should check the small hose next to your clucth cable because it is inposible for your clucth cable to leak coolant because it doesn't have any...</TD></TR></TABLE>
its the one that has the gay little 4 way metal piece is it one is for vacuum one is for rad fluid
I had a mysterious leak in the same area in a DA I had.. it ended up being the hard coolant line across the back of the block, check that if it doesn't appear to be anything more obvious...
crazy though... leaky clutch cable.. lmao
Have you checked your blinker fluid reservoir? When you pop the "rad cap" you no longer have pressure in your cooling system, thats why your spray stops. Either you have a hole in your coolant hose (to the radiator) or possibly a leak near the aforementioned "gay" IAC valve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">time to replace the o-rings in your clutch cable duh!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz »</TD></TR><TR><TD CLASS="quote">Have you checked your blinker fluid reservoir? "gay" IAC valve?
gotta be the clutch cable o-rings.. or the blinker fluid..maybe a muffler bearing? could be the IAC valve has homosexual tendencies though.. maybe a bad flux capacitor?
i really think its that the iac is just cumming on its homosexual under the hood lover. your gunna have to try some reverse xmbsk983 non horny iac condoms otherwise take one of the partners away from each other or it wont stop but its bad to just take loves away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 503_EF9 »</TD></TR><TR><TD CLASS="quote">i really think its that the iac is just cumming on its homosexual under the hood lover. your gunna have to try some reverse xmbsk983 non horny iac condoms otherwise take one of the partners away from each other or it wont stop but its bad to just take loves away.
Thats just gay
</TD></TR></TABLE>Thats just gay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 503_EF9 »</TD></TR><TR><TD CLASS="quote">i really think its that the iac is just cumming on its homosexual under the hood lover. your gunna have to try some reverse xmbsk983 non horny iac condoms otherwise take one of the partners away from each other or it wont stop but its bad to just take loves away. </TD></TR></TABLE>
Damn, these 07 members a f'ing weird!
jyacoba2009
Dec 6, 2009 07:35 AM
Spence
Sep 28, 2004 05:20 PM
