JDM 98 spec ITR rear rotor question.....
Is the JDM 98 SPEC ITR 5-lug rear rotors the same size as the USDM ITR 5-lug rear rotors? I know the fronts are different, but what bout the rears?????
the front rotors are different because they run a 32mm hub on the USDM, while the JDM is 36mm. Does that affect the size of the rotors for the front? so the rears are the same as the 98 spec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 »</TD></TR><TR><TD CLASS="quote">the fronts are bigger in diameter, obviously, but as far as hub deminsions the JDM=the USDM
or what eer you want to call them</TD></TR></TABLE>
Actually Andrew, that is incorrect. The front rotors are the same diameter as the USDM rotors, 98+ JDM spec that is.
PS, Andrew, you will be getting a call soon for a get together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 »</TD></TR><TR><TD CLASS="quote">allow me to clearify, fronts are bigger then the rears in diameter
<--Andrew patiently waiting by the phone</TD></TR></TABLE>
LOL, duh (my bad mang)
and I won't be calling you tonight
<FONT SIZE="10"><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">98+ JDM = USDM ITR (all years)</TD></TR></TABLE></FONT>
Whats hard to understand about that? The hub not does NOT affect the rotor size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR1148 »</TD></TR><TR><TD CLASS="quote">the front rotors are different because they run a 32mm hub on the USDM, while the JDM is 36mm. Does that affect the size of the rotors for the front? so the rears are the same as the 98 spec? </TD></TR></TABLE>
You have no idea what you are saying. You make a statement, then question yourself.
Prox_Denali199
Mar 24, 2020 08:09 AM
