Head
Old Jul 2, 2007 | 04:34 PM
924doorEG's Avatar
Default Head
my head is about to go into the machine shop, what ports do you have them smooth down the exhaust or intake ports?
Old Jul 3, 2007 | 10:25 AM
PhantomLord's Avatar
Default Re: Head (924doorEG)
Do both.
Old Jul 3, 2007 | 10:39 AM
sohctodohc's Avatar
Default Re: Head (PhantomLord)
no i think you want the exhaust to be smooth and the intake to be rough.
Old Jul 3, 2007 | 10:43 AM
1992Si's Avatar
oh god,
Do both... If the shop has to ask you better go some where else.
Old Jul 3, 2007 | 10:45 AM
951BRO's Avatar
Default Re: (1992Si)
exhaust smooth, intake more open and rough, but open both up a little
Old Jul 3, 2007 | 12:46 PM
Magik123's Avatar
just my 2 cents please feel free to debate but every honda motor ive seen port and polished ended up doin worse on the air flow bench.... from what i have heard honda designes the head to cause a swirling motion which builds pressure so when the intake opens again its kind of like F.I and smoothin the ports out negates this. Maybe with boost you wouldnt notice this ... ask the shop to flow bench b4 and after to make sure u got ur moneys worth
Old Jul 3, 2007 | 12:50 PM
Preferio's Avatar
Default Re: Head (Magik123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 &raquo;</TD></TR><TR><TD CLASS="quote">honda designes the head to cause a swirling motion which builds pressure so when the intake opens again its </TD></TR></TABLE>
Hahahahaahahaha...
Old Jul 3, 2007 | 01:28 PM
forcefedferio's Avatar
Default Re: Head (Preferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 &raquo;</TD></TR><TR><TD CLASS="quote">just my 2 cents please feel free to debate but every honda motor ive seen port and polished ended up doin worse on the air flow bench.... from what i have heard honda designes the head to cause a swirling motion which builds pressure so when the intake opens again its kind of like F.I and smoothin the ports out negates this. Maybe with boost you wouldnt notice this ... ask the shop to flow bench b4 and after to make sure u got ur moneys worth </TD></TR></TABLE>
i have heard this is true and i have also SEEN it in action 4 honda heads, all being LS heads, all ported and polished and put on the flow bench before and after 2 of them flowed better beforehand without even any prior cleaning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">no i think you want the exhaust to be smooth and the intake to be rough.</TD></TR></TABLE>
both smooth for fuel injection, it's carbureated you want the roof of the port to be slightly rough.
Old Jul 3, 2007 | 01:30 PM
pimpinblackcivic's Avatar
this thread could go on and on as theres two schools of thought on rough v smooth - i agree that its worrying that the shop are asking you!
Old Jul 3, 2007 | 02:07 PM
MJ0LNIR's Avatar
I was in on this thread until I read the posts.
Old Jul 3, 2007 | 02:51 PM
Magik123's Avatar
lol shoulda seen that comin .... but im just tellin u what i was told by a 23yr owner of a machine shop .... using the terms cuz its easy to understand
Old Jul 6, 2007 | 07:58 AM
Your going to gain most of your power by port matching the intake manifold to the head. Another good thing to do is to get rid of the casting lines inside the ports. As far as making the ports bigger all the way through, you will not gain much on an n/a motor. The reason people say not to smooth the intake to much is because the gas will stick to the sides of the ports more instead of going right into the combustion chamber. You definately do not want to pollish your intake ports to a miror finish or anything like that. As far as Honda saying they design the intake mani to cause swirling, I've worked on a large number of honda intake manifolds and never seen this. However all the intakes I have worked on have been older motors like the y8. The newer honda motors may actually do this. Not saying that Magik123 is wrong, just sayig that I think that only applies to the newer cars.
hondachris1994
13
Aug 21, 2008 06:56 AM
redboost10
Jan 1, 2007 01:35 PM
ToeJam
Oct 8, 2006 10:10 AM
RACEPAK
Oct 2, 2005 03:57 PM
xDicktonesx
44
Jun 4, 2005 12:12 AM
