K24 Monster
Old Jul 2, 2007 | 04:11 PM
Smith bPr's Avatar
Default K24 Monster
Hi. Newb here...
Just thought i would post up alittle and introduce myself.. I have a Blue 02 RSX-S.
I bought the car a year ago and had bought some things for it.
It had a DCRH, Injen CAI, Comptech Exhaust, Tein SSP Coilovers, Kpro, ACT Extreme clutch, Prostreet 8lb flywheel. The cars best run was a 13.63 at 102.3 http://videos.streetfire.net/s...a.htm
About 5 months ago the motor let go on me and completely blew apart. The block was worthless and the head would take lots of money to fix. soooooo...... I bought a K24 swap out of an element.
Here is what is going on.
The head......
After the car blew up i did my research on all the local shops and finally found one that i was REALLY impressed with. It is smith's Automotive in Frankfort. Ok and i liked the name. lol. But they sent the head off to get it fixed from the grenade that went off in it. and once they got it back they went to town on it. First i had the head ported which opened it up ALOT. more on the exhaust side then the intake. Also included on the head are Crower Titanium Retainers, Crower Dual Valve Springs, and Crower Flat top intake and Exhaust Valves. The keepers(retainer Clips) and Seals i just kept stock from honda. Im not sure as to what cams i am going to be running in it. I am still doing my research on that and figured id let the new motor break in on stock cams. The head is being placed on a cometic headgasket and held down with ARP studs.
Here are pic sof the head......
The Block......
Is in the process of still being built. It should be back next week. It is the block out of a Honda Element (k24a4) which unfortunately is the one block that does not just mount up to the k20 head. As far as the internals go on this i am sticking with stock TSX Rods and Pistons and the stock Crank. The crank is being knife edged and balanced. while all rod and piston combos will also be balanced to weigh the same. I went with ACL Rod and Main bearings and Stock Rings.
Pics soon to come.....
The rest of the build....
The car is being tuned with Hondata K-Pro and as far as who is tuning it i havent decided yet. I have been in touch with a shop in NY that has done this swap and they donated a map to the project to play around with so that i will have something to start with. I am in the middle of purchaseing new fuel injectors, rail, and pressure regulator. The other bolt ons that will be on the car is a Buddyclub Race Header followed by Comptech exhaust, Injen CAI, and a EP3 K20A NPR3 CTR Transmission w/ LSD with ACT extreme clutch and a Pro Street 8lb Flywheel. I also went ahead and replaced the motor mounts with Innovative's Race kit mounts. And the last thing so that i can monitor the motor was the A/F guage.
My Guage...
Buddyclub Race Header....
Tranny.....
And the final touch which my roomie got me...
because the block came out of an element.
Old Jul 2, 2007 | 04:16 PM
phthalo's Avatar
GDD4LIFE
Default Re: K24 Monster (Smith bPr)
ballin!
how exactly did your old engine blow apart on you?
Old Jul 2, 2007 | 04:22 PM
Smith bPr's Avatar
Dont exactly know how it did but the valve hit the piston at around 7k rpm. check it out...
Piston in 2 pieces
Everything out of oil pan
Old Jul 2, 2007 | 06:13 PM
epclean3's Avatar
Oh damn!!! Well it looks as if the K did what they're known for best and that's to lean way out on cylinder 3 and cause some serious issues. Good luck on the next motor, to try and keep myself from detonation I have to keep my motor running rich at around 12-12.5:1 A/F ratio.
Oh and for cams i'd definately run the Crower stage 2's or even run Skunk2 Stgage 2's, I'm running Skunks in mine and they're very responsive and streetable. Hit up Tai at CorSport and tell him I sent you his way, http://www.corsportusa.com
Mendoza
Old Jul 2, 2007 | 07:58 PM
aznvietboi87's Avatar
/subscribed.
Old Jul 2, 2007 | 11:23 PM
k20nsyd's Avatar
damn!! gl with next build
Old Jul 3, 2007 | 06:24 PM
Smith bPr's Avatar
thanks. hopefully it will all be done within the next week.
Old Jul 3, 2007 | 06:54 PM
inspireAZN's Avatar
Too much vtec
Old Jul 3, 2007 | 09:57 PM
Smith bPr's Avatar
lol
Old Jul 4, 2007 | 04:14 AM
gripnslide's Avatar
give me???
Old Jul 4, 2007 | 10:32 AM
dc5 divi's Avatar
Default Re: (Smith bPr)
damn!
Old Jul 4, 2007 | 10:40 AM
ilovemydc5's Avatar
Damn bro, i havent seen one like that in a while since my buddy blew up his mini me civic. must be nice to have another project to do. an to have the money to get it done. im glad i have another 3 year warranty on my shitz nit. good luck with the build very sexy!
Old Jul 4, 2007 | 04:08 PM
Smith bPr's Avatar
Here are a few pics of the car the motor is going in.......
Here she is lowered with the stockies......
Here it is with the FULL k24 in it.... but it was only in for about a week then it came out so that the block could be built. lol i just thought it looked funny in there..
and best for last.. here she is as she sits....
Modified by Smith bPr at 10:30 PM 7/4/2007
Old Jul 4, 2007 | 09:28 PM
ilovemydc5's Avatar
god skeet skeet skeet!!! sexy looks like a base model also must be nice.
Old Jul 5, 2007 | 10:41 AM
Hyjnx's Avatar
so ur not using the RBC intake manifold i see...is that a possible upgrade? or did u choose the one u got to make sure u dont have to deal with the water squirter problem? i do notice an intake velocity stack? looks sweet ive been lookin into it for the Ep3 a nice k24a2 possibly strokin it out to 2.6 k26 then a type s head serious vtec...
anyways looks awesome man subscribed for sure
Old Jul 5, 2007 | 06:08 PM
Smith bPr's Avatar
no i am going to be using the stock intake manifold. i had it port matched to the head and will be getting a throttle body for it here shortly.
the pic of the motor in the car isnt the build. that was just the k24 that i bought. i figured i would play around and put it in the car first to see how it turned out but i ran into a few small problems and just took it out to build it.
Old Jul 12, 2007 | 08:18 PM
Smith bPr's Avatar
Man nothing pisses me off more than a shop telling me that i can come pick up my motor and then getting there to find out it isnt done. i freakin live an hour away from the shop. but i guess it is my fault for not calling first. But i did see it and all the work is done. it is just waiting to be assembled. They promised it to me tuesday so i guess i have to wait a few more days.
It just sucks because i had my hopes up on getting my car back since it has been down for 5 months. plus i took off of work for the next 4 days for putting it all together and hacing time to enjoy it.
Old Jul 12, 2007 | 08:34 PM
MidNit's Avatar
Oh man, I hope you get it back soon... Let me know how it runs with all that headwork!
I did a straight k24a2 swap about a month back. Engine only had ~15k miles on it, runs great! Engine bay shot for the win!
Also a shot lowering the car onto the sexy new engine!
Sorry for threadjacking I'm just excited for you man. Yours is going to run so nice, you'll love it!
I don't know if I read right or not, but it looks as though you're using the k24's prb IM... Any plans to upgrade that? I'll be getting my RBC and bored TB back on Monday, I can let you know how it goes.
OH! AND VBP FTW!
Old Jul 12, 2007 | 08:36 PM
MidNit's Avatar
Yeah, Im a dumbass, you did say something about the IM... My bad!
Old Jul 13, 2007 | 08:07 AM
Smith bPr's Avatar
lol im still using the stock IM but it is being port matched to the head and im getting a 70mm throttle body for the other end.
Old Jul 13, 2007 | 08:10 AM
Unbreakable6161's Avatar
sick
Old Jul 13, 2007 | 09:13 AM
MidNit's Avatar
Damn dude, I'd love to get the 70mm but it's like almost $300...
I'm just planning on paying the $100 to get it bored out to 65mm. Got the RBC and Karcept's adapter on their way this weekend or next week sometime hopefully
Old Jul 13, 2007 | 08:00 PM
Smith bPr's Avatar
yeah its expensive but you have to pay to play.
Old Jul 14, 2007 | 01:26 PM
Jtuned DC2's Avatar
* B A N N E D *
sick man, The type-s looks dope dropped on those stockies
Old Jul 24, 2007 | 09:51 PM
Smith bPr's Avatar
well here is a little update. motor is in but i havent tried to start it yet.....
