Type-R tranny problem (2nd gear is fussy)
Old Jul 2, 2007 | 03:41 PM
Hatchorama's Avatar
Default Type-R tranny problem (2nd gear is fussy)
I bought a type-r tranny for my B20 vtec that had a new shift fork put in it, but all the gears, synchro's, and bearings are either new or in perfect condition. But for some reason 2nd gear is fighting me a little bit. It will hardly ever go in at all if you're down shifting and it fights a little bit to get in 2nd gear when accelerating, slow or fast, it doesn't matter. There's no grinds and it's only 2nd gear giving me a problem. What should I do, or what do you think might be causing this??? Thank you for your time.
Old Jul 4, 2007 | 08:48 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Type-R tranny problem (Hatchorama)
shift linkage maybe?.. driver?
Old Jul 4, 2007 | 08:32 PM
Hatchorama's Avatar
I was using a b16 tranny before which is the same dimensions, and no it's not me, I'm not the best driver, but I'm deffinately not bad by any means, I think it's the style shift fork that we used. I'm going to try and use a 1997 type-r style 1-2 shift fork.
Old Jul 5, 2007 | 07:28 PM
Default Re: Type-R tranny problem (ohsnapzafingcu)
i know a guy that had the same problem, he could barely get it into 2nd.. he thought the shift fork was benta nd sold it for cheap..
Old Jul 6, 2007 | 06:58 AM
Gearspeed-Performance's Avatar
If all the gears, selectors, and synchros are good..there should be no problem. Check to make sure that a washer was used under the detent bolts(the one that holds the ball and spring assemblies on the side of the main case). A lot of people forget that washer underneath the bolt and it will give them some shift issues to say the least!
98bucket
Sep 17, 2008 10:09 AM
boosted_EM1
12
Feb 7, 2008 12:58 PM
kihun_cha
Dec 3, 2005 09:12 PM
mikestypeR
Mar 2, 2004 04:44 PM
