Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2002 Honda CRV - Thump below.
Old Jul 2, 2007 | 01:07 PM
daewalker's Avatar
Default 2002 Honda CRV - Thump below.
I just purchased a 2002 Honda CRV LX and it makes a thumping noise once in a while after I switch from reverse to drive, then accelerate. It will thump about 2-5 feet after acceleration, and it only happens sometimes, not always. Anybody know what this could be? Sometimes it's from the left side, and sometimes from the right. Please help.
Old Jul 3, 2007 | 05:28 AM
crvpimpin's Avatar
Default Re: 2002 Honda CRV - Thump below. (daewalker)
sound like a diff problem maybe
Old Jul 3, 2007 | 08:53 AM
Ross 2.0's Avatar
In a Junkyard near you.
Can you feel the thump in the gas pedal? It may just be the ABS self check.
Old Jul 8, 2007 | 11:31 AM
Aahj's Avatar
Is it a thump or a higher pitched knock? I've seen that the front lower control arm bolts sometimes need to be retorqued. For some reason, they back off ever so slightly and the car will make a knocking noise.
AJ
Old Jul 8, 2007 | 03:25 PM
daewalker's Avatar
Default Re: 2002 Honda CRV - Thump below. (Aahj)
it sounds as you describe it. so what do you mean by retorque? i have no idea what that means.
you sound like you know what the problem is though.
Old Jul 8, 2007 | 06:10 PM
Aahj's Avatar
There are two 19mm hex bolts that hold the front lower control arms to the subframe on each side. I found that retorquing (i.e. re-tightening with a good impact gun) them fixed the problem. It's mainly the rear bolt, but do them all just in case and see what happens.
Old Jul 8, 2007 | 07:43 PM
daewalker's Avatar
wow, now that's being specific. thanks so much! i'll try it sometime this week and let you know what happens. thanks a lot!
Old Jul 9, 2007 | 03:24 PM
Aahj's Avatar
No worries...good luck!
AJ
alscrx
29
Aug 10, 2021 11:23 PM
Davidgboogie
Sep 10, 2017 09:11 AM
fedex
Honda Civic (2001 - 2005)
10
Aug 27, 2010 11:32 PM
prelude1988
Dec 25, 2008 10:17 PM
BoostedGSRBubble
Nov 4, 2003 05:04 AM
