Quick brake q, just for reinsurance
ive got these parts in my garage, but im not 100% sure if i am missing something, any help is greatly appreciated since my car needs new pads and rotors. My car is an 99 accord ex coupe 4cyl 5spd.
1. Honda Accord 97 v6 rotors
2. Acura Legend Calipers w/ 23T brackets
3. Hawk HPS front(Legend) and rear(99 accord 4cyl) pads
4. 98-02 4cyl Accord rear slotted rotors
5. SS brakelines on route
i need new brakes and i cant drive my car until they are replaced, so can anyone tell me if ill have a problem with the rotors, calipers, or 23t brackets
i'm assuming your trying to do some type of conversion??
you didn't mention anything in your post about this if you are. And, your post title doesn't make much sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LocOBanAnA »</TD></TR><TR><TD CLASS="quote">i'm assuming your trying to do some type of conversion??
you didn't mention anything in your post about this if you are. And, your post title doesn't make much sense.</TD></TR></TABLE>sorry, since i don't post much.
I was checking if there was anything missing for the brake upgrade. since i have the 4cyl 6th gen, i was hoping the Accord 97 v6 rotors would be compatible with my 23T brackets that came with my Legend calipers. i just dont want to go through all of the work to later find out that the brackets won't fit the rotor or vice versa, etc.
Accord V6's use 25t brackets so you may have some clearance issues Since the number denotes in milimeters the thickness of the rotor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">Accord V6's use 25t brackets so you may have some clearance issues Since the number denotes in milimeters the thickness of the rotor...</TD></TR></TABLE>
does anyone know if i will have clearance issues? i thought the legend calipers/brackets and rotors would be a direct fit without any issues.
ok, I can understand you are in need of an answer but I don't feel there is a need to bump the thread that much, especially if the thread is still on the first page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuroKing99 »</TD></TR><TR><TD CLASS="quote">
does anyone know if i will have clearance issues? i thought the legend calipers/brackets and rotors would be a direct fit without any issues.</TD></TR></TABLE>
Well why dont you get 25t brackets?? That is what is recommended to use with Accord v6 rotors anyways. 23t brackets are only for when using Prelude or Type-R rotors. (I have Prelude vtec calipers and rotors on my Accord)
ohplezz
Feb 16, 2010 03:33 PM
Paul V
Jun 6, 2005 05:31 AM
MJ23FE
Nov 19, 2002 09:12 AM
