NEED HELP!! dx to dohc zc swap
hi im new here been checking it out for awhile finally decided to post, i just did my dx to dohc swap, i got the pr4 ecu from a 91 integra, ordered a premade wiring harness for the swap, got it all together did the little wiring i had to do went to start it and it cranked for a while then finally it started, and ran like ****!! it reved to like 2800 and just bogged, i am throwing code 16 with a cel.i have looked over it a 100 times and everything seems right.....any help will be greatly appreciated.
I think the ecu is you problem because back in the day I had done the same swap and when I drove it it was fine with a crx si ecu or a ZC (best choice) ecu, but for some reason when I plugged in my boy's 91 Teg ecu I would not rev past like 2800 rpm so thats what I think (couldnt hurt to get the right ecu for the swap)
good luck man I hope this helps (if not It could be your timing)
Your dumping too much fuel with that PR4 ecu. Find the one for that motor, try to find a PM7 or a PM8 ecu.
Here is one on ebay: http://cgi.ebay.com/ebaymotors...wItem
Code 16 is fuel injectors. Have you verified that your injectors are spraying properly? And I would also suggest using a PM6, PG7 or PM7 ECU. A PM8 will work as well, but good luck finding one.
oki got the pm6 ecu and car runs much better, it is now blinking 16 times fast, instead before i had a long blink with 6 fast ones, and the cel is still on and my altenator took a ****, im gonna switch that out tomorrow, any other ideas? thanks alot!!!!
DarknessInside51
May 31, 2004 04:20 PM
Dirttylicous
May 17, 2004 05:50 AM
