Seafoam or what...
Old Jul 2, 2007 | 06:15 AM
g2tegsown's Avatar
Default Seafoam or what...
Alright so I went and put a new throttle body on my car, I checked the TPS with my multimeter, and it was the same as the previous throttle body (.5v which I have heard should be .45, but it wouldn't go that low, maybe it's just my meter). Anyway when I started the car it's idle was crazy and the car wasn't running good at all, not driveable. After some inspection I noticed a VERY HEAVY white smoke coming from the exhaust, so I was thinking maybe my Air to fuel was messed up so I put the original TB back on. Started the car better idle, but it was still totally out of whack. After about 3 or 4 mins of running the white smoke disappeared and it had kinda a faint black smoke. And the idle bounced up and down like crazy, I found the map sensor wasn't making a good seal so I made a gasket for it and put it on, well that has about fixed the idle, and it still has a faint black smoke and a LOT of moisture coming out.
It drives good now, but I am still wondering what happened, I notice a pretty strong exhaust odor when I am driving now as well
Now I put half a bottle of seafoam in my gas tank (With $20 worth of gas) about 3 or 4 days ago and I have driven about 100 mi without noticing any smoke or odors. So do you think that the smoke was caused from the seafoam? If it was a cracked head or bad head gasket wouldn't it continue to smoke?
BTW I checked my coolant and it's still at the same level it was.
Old Jul 2, 2007 | 06:27 AM
Allday07's Avatar
Default Re: Seafoam or what... (g2tegsown)
ive read good things, and ive read bad things about seafoam..if your motor has no leaks (oil, coolant) dont use it..if your motor is high mileage, it has gunk buildup that is holding everything together. seafoam is known to be strong and break through that leading to more problems..i just wouldnt use it
and yes, if it conitinued to smoke, then yes it would be a bad headgasket..
hope this helps
Old Jul 2, 2007 | 06:36 AM
g2tegsown's Avatar
Well it's a CRX w/ a B16A2 (1999-2000 Civic Si) so my guess is the mileage is about 60,000-120,000 miles, however the motor is in incredible condition so I tend to think it's under a 100K.
Modified by g2tegsown at 11:27 AM 7/2/2007
Old Jul 2, 2007 | 06:38 AM
g2tegsown's Avatar
Also does anyone think that maybe all the carbon build up got spit into my cat and now my cat is clogged up?
Old Jul 2, 2007 | 07:29 AM
g2tegsown's Avatar
I took my car out on a service call, and when I got back I noticed some faint black smoke in my exhaust (after the car was off) and a lot of moisture again. Still a very strong exhaust odor when driving as well.
Old Jul 2, 2007 | 07:47 AM
thesmogman's Avatar
Default Re: (g2tegsown)
First off, read the instructions. I think you have too much Seafoam in the tank.
I believe it is a third of the can treats 20 gal.
It would not clog the cat, Not big enough particles.
Old Jul 2, 2007 | 07:52 AM
IT GUY's Avatar
How many miles since you added the SeaFoam? (nevermind saw you said 100) When I've used it in different cars, the first 50 miles seem like the car may fall apart but it gradually gets better through the tank of gas.. the moisture should be there (seafoam helps clear water from fuel tank) so as the seafoam (some people use alcohol for this purpose) carries the water without through the combustion process.. seafoam is able to burn leaving water vapor to exit your exhaust, but as it cools becomes droplets you see coming out of your tailpipe. you'll get a little residual smoke for probably the rest of the tank of gas (alot of stuff to burn up first in combustion then again by the catalyst)
keep on driving unless that moisture looks like antifreeze
Old Jul 2, 2007 | 07:57 AM
g2tegsown's Avatar
No if defintily looks like water, doesn't have the nasty AF smell either. I have be doing some reading and I really do think it's seafoam, it's just weird it came all at once. Maybe because it's getting lower on the tank of gas. I looked at my oil yesterday and it was a little dark, but it looked fine, I am going to do a more indepth look when I get done work. Also I checked my coolant and it looked like the same level.
Modified by g2tegsown at 12:10 PM 7/2/2007
Old Jul 2, 2007 | 08:51 AM
IT GUY's Avatar
Default Re: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">First off, read the instructions. I think you have too much Seafoam in the tank.
"When Added to Fuel Tank
Cleans fuel injectors and carburetor jets
Cleans carbon as you drive
Lubricates upper cylinders
De-ices and removes moisture
Diesel full conditioner and anti gel
Stabilizes fuel
One pint treats 8-25 gallons of fuel (average 1 ounce per gallon). "
you use less if you piggyback on a vacuum line to the intake, but he used the correct amount for in the tank.
Old Jul 2, 2007 | 09:29 AM
g2tegsown's Avatar
Yeah I read the directions over and over to make sure I didn't make any mistakes. It just freaked me out because I drove the car for quite a bit with no results, then I started it yesterday and tons of white smoke started coming out. So do you guys think it was the seafoam?
Old Jul 2, 2007 | 10:10 AM
IT GUY's Avatar
IMO it was the seafoam..
Old Jul 2, 2007 | 10:12 AM
g2tegsown's Avatar
Default Re: (IT GUY)
Thanks so much IT Guy and everyone who posted, it's nice to have people actually help you on this board for a change.
Old Jul 2, 2007 | 08:14 PM
Allday07's Avatar
yea, theres alot of legit people on here
but with the seafoam, did you actually notice anything? im currently running a jdm d15b, but going withthe b16 sooner or later so im just gonna try it out i guess
Old Jul 3, 2007 | 12:37 PM
g2tegsown's Avatar
I did notice the engine seems to start easier and feels a little smoother during daily driving. I can't say I felt any increase in power or anything like that
96hatchBoy
Sep 18, 2012 03:45 AM
sk8kingda3rd
13
Jul 21, 2011 11:51 AM
jawsiiv
Mar 8, 2010 05:47 AM
YellowR2000x2
May 22, 2005 02:04 AM
delSolLS
Feb 18, 2002 04:59 AM
