Check Engine light comes on at high rpm
Old Jul 2, 2007 | 05:36 AM
CarnEvil's Avatar
Default Check Engine light comes on at high rpm
On a hard pull my check engine light will come on at higher rpm when i am at full throttle. When the code appears my fuel (perhaps spark too) is cut and the light stays on until i lift off the throttle. At which point i can accelerate again. I am running an s300 and I tried logging the code but it doesn't show up.
One thing to note is that i have an IAC code but the IAC is known to be good. Hondata allows you to disable this code which i have done. A compounded problem which i'm trying to see if they are related is that i have a touchy throttle which i thought could be attributed to a vacuum leak, but everything looks solid. I removed the IAC to check if it was clean and then bolted it on again and it seemed to behave better. Throttle not so touchy, and i could pull harder without calling that code as early in the rpm range.
Let me know if these symptoms sound familiar, Because it's a real pain in the *** to be racing that chevelle and having my throttle cut off right at peak power ! (still beat him tho )
general specs:
98 Civic coupe
b18c (gsr) bored to 2L
S2 stage 1 cams
9.0:1 compression
gt35r
Old Jul 2, 2007 | 06:20 PM
CarnEvil's Avatar
Default Re: Check Engine light comes on at high rpm (CarnEvil)
bump
Old Jul 2, 2007 | 07:09 PM
builthatch's Avatar
MiG-21 superfan
hmm, you have to be able to read that code(s), otherwise it's shots in the dark...
i know you know that but i'm just reinforcing it.
does the s300 have something that indicates certain issues by doing what it's doing? like with the Power FC, the CEL will flash at one interval for knock over a set level, and at another interval for injector duty going over a set level...
Old Jul 2, 2007 | 07:20 PM
NJIN BUILDR's Avatar
Your hitting boost limit or rpm limit.Either will light cel without coding.
Old Jul 2, 2007 | 08:05 PM
b18bEKcoupe's Avatar
You dont happen to have the check engine light setup as a shift light do you? Just checking.
Old Jul 3, 2007 | 05:10 AM
CarnEvil's Avatar
Default Re: Check Engine light comes on at high rpm (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Your hitting boost limit or rpm limit.Either will light cel without coding.</TD></TR></TABLE>
My rev limiter is set to a fixed point whereas this is a variable issue.
When you say boost limit you must be refering to the boost cut feature right.
Oh thankyou thankyou thankyou thankyou thankyou
I just checked my calibration file and my boost cut is at 20psi. I've done a peak and hold on my boost controller and i've maxed out at 20psi. Makes perfect sense. So my ecu is acting as my boost controller since my boost controller is asking for more than the ecu will allow. I'm goiing to set my controller to 20 pounds and have the ecu shaddow it at 25 pounds just for safety.
I'll post and tell you how it made out, i'm gonna flash it after work tonight.
Thanks so much for your help........... I love this site!!
Old Jul 3, 2007 | 12:20 PM
CarnEvil's Avatar
There we go, it's rockin now.
It's ridiculously fast now....It was cutting me off right in it's peak power band, but now it's crazy.
Thanks for your help guys.
Old Jul 3, 2007 | 04:36 PM
EG civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEKcoupe &raquo;</TD></TR><TR><TD CLASS="quote">You dont happen to have the check engine light setup as a shift light do you? Just checking.</TD></TR></TABLE>
I was thinking the samething hahaha.
Bostonbob
Apr 6, 2017 09:14 AM
Djmontiel
Feb 16, 2016 01:30 AM
gettin it
10
Jan 4, 2008 06:53 AM
bokguay
Mar 19, 2003 10:11 AM
