check engine light
Check over your work, you probally left something unpluged or pulled something off. Check your codes by pulling up the pass. side carpet and count how many times your ecu flashes.
It is where your feet would be on the passenger side if you stretched them out. Pull up the carpet and you will see a goldish kick panel covering your ecu. There will be a hole in it. Turn your key to the on posistion and you will see a blinking red light in that hole. Count how many times it blinks and get back to us. It could be more than one code,so make sure you double check.
rudyndrew
Jan 5, 2011 05:32 PM
89civichb
May 10, 2007 06:42 PM
