Engine Builders. Whats happened to these bearings.
My motor was assembled by my dads machine shop, hes not use to honda motors, but does great work. After 1500-2000 miles my block started to knock. Pulled the motor and here is what we found:
Eagle Rods / ACL Bearings
The clearances were within OEM spec, but on the tight side. Any ideas on what the cause is? Were thinking overheated bearings because of the clearances? Any other ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker »</TD></TR><TR><TD CLASS="quote">How does the crank look?</TD></TR></TABLE>
yeah, are any of the crank journals scored or anything???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker »</TD></TR><TR><TD CLASS="quote">Are you sure it didn't have too much clearance?</TD></TR></TABLE>
no, the tightest ones were .0008".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott_Tucker »</TD></TR><TR><TD CLASS="quote">No heavy detonation?</TD></TR></TABLE>
No, it were no signs on the pistons, I have not looked at the plugs. There was no reason for heavy knock. The only thing maybe bad gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951BRO »</TD></TR><TR><TD CLASS="quote">forget assy lube?
i prefer honda bearings man i hate acls, let me guess this sht happened before you tuned? </TD></TR></TABLE>
It's not from dry startup.It's not from lack of oil.I've used ACL's with good luck and haven't had these problems.
i prefer honda bearings man i hate acls, let me guess this sht happened before you tuned? </TD></TR></TABLE>It's not from dry startup.It's not from lack of oil.I've used ACL's with good luck and haven't had these problems.
No. Tuning was done as soon as i turned the key. By Turbogixxer(Kenny).
i prefer honda bearings man i hate acls, let me guess this sht happened before you tuned? </TD></TR></TABLE>No. Tuning was done as soon as i turned the key. By Turbogixxer(Kenny).
.0008" is on the tight end of the spec. I'd go almost double that on a performance build. I targeted mine for .0015" when I built my motor a couple of years ago. Still runs perfect with rev limit at 8750.
Also use a stretch gauge when you torque the rod bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Industry »</TD></TR><TR><TD CLASS="quote">.0008" is on the tight end of the spec. I'd go almost double that on a performance build. I targeted mine for .0015" when I built my motor a couple of years ago. Still runs perfect with rev limit at 8750.
None of the building was done by me or OMG B16. When we get it apart, it will be checked better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">any update on this?</TD></TR></TABLE>
Yes. Here https://honda-tech.com/zerothread?id=2038326
Toadfart
Sep 23, 2005 03:54 AM
