Where is my PMG-FI main relay
look at your footrest (that black square thing where you rest your left foot on) follow it to the bottom then move to your extreme left toward the side of the car, then down a bit.
you will see a small grey square box (3" by 1") with 8+ wire going to it. its held in with a 10mm bolt.
still cant find it. remove your carpet in that area, then you will see the square box.
all 92-00 civics and 94-00 integra's use the same relay, so testing is pretty easy if you have friends with hondas
also if you didnt know...removing it creates an oem kill switch aswell...
JDMDRAGON
Oct 5, 2007 05:00 PM
uneekcrx
Apr 11, 2002 06:59 PM
