wiring vtec into a non vtec harness...
Old Jul 1, 2007 | 06:37 PM
Eg_TypeR's Avatar
Default wiring vtec into a non vtec harness...
B4 ppl start freaking out... I have searched and i only find the info i already knew about...
Im wiring vtec into a buddies harness, and i was planning on just running new wires from the vtec plugs to the ecu.
Im using the vtec wires from a JDM Type r harness, but one of them branches off into i believe are the iacv, iat sensors?.. am i correct has anyone ever gone through this?.. should i re wire the other sensors up or can i just run the vtec plugs??...
Please help!!!... any info will help?
Old Jul 2, 2007 | 06:20 AM
ndogg's Avatar
Default Re: wiring vtec into a non vtec harness... (Eg_TypeR)
they have nothing to do with vtec. on some swaps iacv and iat are actually different connections though and you need to swap them. for example, on my obd1 GSR into obd2a civic, i reused my obd2a harness but the iacv and iat plugs didn't fit so i stole them from the GSR harness.
what are you trying to do?
Old Jul 2, 2007 | 09:39 AM
Eg_TypeR's Avatar
Default Re: wiring vtec into a non vtec harness... (ndogg)
well i just wanted to take out the vtec wires, and use them in the original non vtec harness... and i wanted to know if i should run the others aswell?
Old Jul 2, 2007 | 10:07 AM
ekb16's Avatar
only run what you need to run to make everythin work for you
Old Jul 2, 2007 | 11:07 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (ekb16)
what is the setup?
Old Jul 2, 2007 | 11:26 AM
Eg_TypeR's Avatar
has anyone ever seen the wires splice into other sensors like i described above??..
Old Jul 2, 2007 | 12:34 PM
ndogg's Avatar
just cut the plugs off and leave like 6 inches of wire then solder it to a new wire and run it to the ecu.
Old Jul 2, 2007 | 03:00 PM
Eg_TypeR's Avatar
no no no... thats just hack!!..
im running it with all the harness wires to the main harness clips... then from the other clip to the ecu.
Old Jul 2, 2007 | 04:03 PM
ndogg's Avatar
if you do it right it can look clean. just wire it to the shock tower and pin it in there. then wire it from the shock tower to the ecu... trying to take the whole wire out is just hassle for basically nothing.
Old Jul 2, 2007 | 07:13 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">if you do it right it can look clean. just wire it to the shock tower and pin it in there. then wire it from the shock tower to the ecu... trying to take the whole wire out is just hassle for basically nothing.</TD></TR></TABLE>
x2
esp when you wrap everything, noone will ever know the difference.
waynesumner
Jun 16, 2013 06:36 PM
Jay_Mills
Transmission & Drivetrain
Jun 14, 2011 03:13 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
HaNsElBaDaSs
Oct 19, 2006 11:17 AM
quicksol95
Mar 19, 2004 01:50 PM
