h23 timing belt
Old Jul 1, 2007 | 06:11 PM
sleepinlude's Avatar
Default h23 timing belt
Im going to be doing a timing belt and water pump on my 92 prelude. what other parts should i replace while im in there.
Old Jul 1, 2007 | 06:21 PM
Hawkze_2.3's Avatar
Default Re: h23 timing belt (sleepinlude)
I'd see if you have any oil leaks in there, but not much other than that. The manual tensioner shouldn't be a problem unless it's really old and you could replace the balance shaft belt (but I would leave it off if I were you ) Balance shaft seals can leak but not always, so you could check that out too.
Old Jul 1, 2007 | 06:59 PM
biozepox's Avatar
* B A N N E D *
adjust the valve lash
h23 crew hurrr
Old Jul 1, 2007 | 07:10 PM
esedulerp5tenin's Avatar
Default Re: h23 timing belt (biozepox)
you have the crank pulley holder tool right? my t-belt job WAS impossible without it!!
Old Jul 1, 2007 | 07:15 PM
xxmastermindxx's Avatar
Default Re: h23 timing belt (esedulerp5tenin)
now that you mention that crank pulley holder tool, how exactly does it work? i need to get one, but what, does it fit inside the pulley, just outside the bolt? and you have to hold that while turning the crank bolt?
Old Jul 1, 2007 | 08:36 PM
Default Re: h23 timing belt (xxmastermindxx)
theres a hexagon indent in the crank pulley that this tool sits in
http://www.amazon.com/Alltrade...r=8-1
then you attach a 1/2" breaker bar and rest it against the ground, and a 19mm socket goes thru the hole in the middle to the bolt.
a 2' extension also helps to clear the fender
Old Jul 1, 2007 | 08:41 PM
lol you know what i tried today? well i have a flywheel tooth holder thing, but i couldnt get that to work properly (and now that i think about it, i think i know what i did wrong). instead i used a flat blade screwdriver to hold the flywheel, and it held just fine. i had a 19mm socket on crank pulley bolt, an extension, a breaker bar on the end, and as a cheater bar.... a 10 foot piece of 1 1/4" conduit
the weakest link ended up being the 19mm socket, cracked right in half, and that bolt didnt even budge.
Old Jul 2, 2007 | 08:45 AM
haha that sucks. if its craftsman, lifetime warranty baby!!!!
thats why i used an IMPACT socket from my air compressor
Old Jul 2, 2007 | 10:57 AM
mattsnooz's Avatar
if its "crapsman" that's why it broke in the first place!
(I go through 25-50 crapsman/mastercrap different tools/accessories a year, so now I keep a box just for receipts from those two retailers)
Nice move with PVC conduit. that was my leverage for doing the same job.
Spray a bit of penetrate (don't get on pulley some how magically or belts for that matter) a couple hours b4 job.
Randysi
12
Oct 20, 2011 03:00 AM
92hondalude
May 20, 2009 09:48 AM
dfabulous
10
Dec 9, 2007 11:00 PM
tarheelsoldier
Feb 2, 2007 05:35 PM
pArAdOxsqUArE
Jul 18, 2004 08:18 AM
