aem v2 (strange sound)
Old Jul 1, 2007 | 05:28 PM
Winlight's Avatar
Default aem v2 (strange sound)
i put my aem v2 last night and it makes a funny sound that kinda sounds like my tire is rubing on somthing.does anyone els hear that with there aem v2?
Old Jul 1, 2007 | 05:35 PM
ke98248's Avatar
Default Re: aem v2 (Winlight)
No. I hear a whistling/sucking sound at higher rpms..
Old Jul 1, 2007 | 05:42 PM
97Ej6mike's Avatar
Maybe its a coincidence? Check to make sure your wheel well covers (splash guards) arent falling out or something. Also make sure theres nothing obstructing the filter (plastic, leaves, wrappers?) look to make sure theres nothing left inside the induction tube itself.
Old Jul 1, 2007 | 06:24 PM
Winlight's Avatar
Default Re: aem v2 (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Maybe its a coincidence? Check to make sure your wheel well covers (splash guards) arent falling out or something. Also make sure theres nothing obstructing the filter (plastic, leaves, wrappers?) look to make sure theres nothing left inside the induction tube itself.</TD></TR></TABLE>i dont have wheel well covers,and i just pulled the filter off and looked insode and there was nothing in there.also checked inside the pipeing and there was nothing there either.im thinking it might be the fact that the intake pipe hits my tranny line mount on my frame rail.
ke98248's Avatar
It shouldn't hit against anything if installed properly.
Old Jul 1, 2007 | 06:26 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight &raquo;</TD></TR><TR><TD CLASS="quote">i dont have wheel well covers,and i just pulled the filter off and looked insode and there was nothing in there.also checked inside the pipeing and there was nothing there either.im thinking it might be the fact that the intake pipe hits my tranny line mount on my frame rail.</TD></TR></TABLE>
Could be , id think you would know that right away. the V2 should have a mounting brack that holds it up by the strut tower, that would keep it from touching/rattling against things.
Old Jul 1, 2007 | 06:27 PM
babolatplaya's Avatar
Default Re: aem v2 (ke98248)
YEA..he;s right i bought a'00 si with I/H/E. It has a AEM short ram intake and it wistles when you give more than 25% throttle. You sure the tire noise isn't from ur tires dude?
Old Jul 1, 2007 | 06:28 PM
Winlight's Avatar
its instaled right,but i have a b16 so maybe it sits a little diferent then it would with the stock moter.idk.
Old Jul 1, 2007 | 06:29 PM
Winlight's Avatar
Default Re: aem v2 (babolatplaya)
i put a piece of ruber where it was hitting between the intake and the bracket and now it sounds a lot better.now it just pulsates
Old Jul 1, 2007 | 06:32 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight &raquo;</TD></TR><TR><TD CLASS="quote">i put a piece of ruber where it was hitting between the intake and the bracket and now it sounds a lot better.now it just pulsates</TD></TR></TABLE>
Sounds like you solved your own problem
Btw, are you sure you bought the correct intake, for example, not a GSR intake, because the manifolds TB position is different between some B series.
Old Jul 1, 2007 | 06:35 PM
Winlight's Avatar
Btw, are you sure you bought the correct intake, for example, not a GSR intake, because the manifolds TB position is different between some B series.</TD></TR></TABLE>i baught the one for the 92-95 civic
idriveanimport
Dec 13, 2003 04:20 PM
daddymaxx
23
Nov 7, 2003 07:01 PM
YNOT
Feb 20, 2003 02:20 PM
jeprox
Apr 17, 2002 10:15 AM
thaigsrdrv16
Dec 28, 2001 08:54 AM
