installing ac in my cx hatch
Old Jul 1, 2007 | 12:07 PM
alex_s817's Avatar
Default installing ac in my cx hatch
hey whats up guys i just bought an entire air conditioning set-up for my 93 cx hatch. it came with everything that i need, and i know i need to install the (dont know name but have it) under the dash in order to run the lines throught the firewall into it. my question is do i have to remove the entire dash to do this or can i just remove the glove box assembly? thanks guys
i have searched and havent found the answer
Old Jul 1, 2007 | 01:49 PM
nsxmatt's Avatar
Default Re: installing ac in my cx hatch (alex_s817)
You don't have to remove the whole dash but it's a tight fit to do so with it in there.
Old Jul 1, 2007 | 02:30 PM
alex_s817's Avatar
Default Re: installing ac in my cx hatch (nsxmatt)
do you think i should just remove the whole thing then? i have never done it before but i will figure it out if necessary
thanks
Old Jul 1, 2007 | 02:40 PM
XkjeldorX's Avatar
removing the dash is not hard at all. Just be carefull and remove all the bolts. If you pull on the dash and it doesnt want to come out there is probably a bolt somewhere that you have to remove. You dont want to brake your dash do you.
Edit: yes remove the whole dash, it will be much easier. DL
Old Jul 1, 2007 | 03:56 PM
nsxmatt's Avatar
Just go to a Honda dealer and ask parts or service for install instructions for the A/C kit which is what went into most every 92-93 since they did not come from the factory with A/C. That will tell you how to install it.
Old Jul 1, 2007 | 05:12 PM
alex_s817's Avatar
Default Re: (nsxmatt)
ok i will thanks
Old Jul 1, 2007 | 08:52 PM
alex_s817's Avatar
Default Re: (alex_s817)
anyone have a link to a diy on how or what to do? anything will help me i am pretty clueless on this one
Old Jul 1, 2007 | 08:58 PM
tumbleking's Avatar
bump or a how to install on the air conditioning for a 99 ek hatch...
Old Jul 1, 2007 | 09:14 PM
thavarin's Avatar
Default Re: (tumbleking)
X2
Anyone know what parts I need to get also for AC install? Thx guys
Old Jul 1, 2007 | 11:45 PM
sireg6's Avatar
honda will just give you instructions for the install?
dns92civhatchcx
Feb 5, 2013 06:43 PM
schtozo
Jun 24, 2007 11:54 PM
Halive
11
Jul 6, 2002 10:49 PM
charjacq
10
Feb 16, 2002 07:23 AM
