Which a/c compressor? Please help a girl out, 110 degrees here and NO a/c!
Ok, so my 91 hf came with a sanden, we swapped the engine with a d15b vtec that now has a matsushita. So I now have sanden hoses/lines with a matsu compressor. I have read that if your engine came with a matsu that a sanden will not bolt up. is this true? Basically I need to know what to do. Either somehow find matsu hoses to match the current compressor, or get a sanden to match my hoses (if it bolts). Thanks so much for any help, I am melting over here.
Im not 100% sure about it bolting up, ive always swapped brackets when i switched engines so even tho im on my 3rd motor i just transfered the old bracket to the new enigine to use my matsu comp. But i know for a fact the lines dont bolt up there orientation is completly different.
If it was me i would pull the old bracket off, and use the old compressor. Other wise you gonna have to change you high pressure line and your suction line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">Use the old bracket and the old compressor. No AC isnt that bad</TD></TR></TABLE>
Speak for yourself
Speak for yourself
x2, if your old compressor worked. Otherwise you can get a new Sanden compressor or new Matsu flex lines.
triangle1020
Jul 16, 2009 05:26 PM
