What axles are these?? Help please
They are not fitting in my trans? Pass. side is really tight and is difficult to get back out. Help please?
Modified by lance_ecl at 12:53 AM 7/2/2007
Modified by lance_ecl at 1:34 AM 7/2/2007
did you change the axle seal on the side the intermediate shaft goes into to a 94 gsr seal? Since you have gsr axles and mid intermed shaft you need the gsr seal on that side as well. they are different sizes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">You got yourself a nice set of 94+ teg driveshafts and half shaft. No ditch those and get 90-93 teg shafts and half shaft so it can fit your B series.</TD></TR></TABLE>
why would he sell those only to buy an older more inferior set? Those will fit fine, why not change a $5 seal and be done with it.
sorry I'm not fallowing the seal part. what seal do I need to change, and what to? What about the pass. side axle?? It is the one that does not fit well? Sorry I made a mistake the axle labeled driver side is pass side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
why would he sell those only to buy an older more inferior set? Those will fit fine, why not change a $5 seal and be done with it.</TD></TR></TABLE>
Inferior? They are just as good lol. I was under the impression that the 94+ were too long and would cause binding on a lock turn.
Inferior? They are just as good lol. I was under the impression that the 94+ were too long and would cause binding on a lock turn.</TD></TR></TABLE>
No, they are exactly the same as long as you use the right mid shaft
HamiltonRex
Feb 22, 2006 03:58 AM
Rywire
May 3, 2004 07:47 PM
bossman032
Mar 22, 2003 01:10 PM
