Head Gasket Help
Old Jul 1, 2007 | 09:43 AM
HybridBB6's Avatar
Default Head Gasket Help
Ok my friend has a 97 Lude and his head is shaved .020 and the person puting his car back togeter says he needs at least a .070 Head Gasket, but the biggest we found was a Cometic .030. Now can he use the 030. Cometic with no problems? Also his car was set up for NA but now has a turbo kit on it. Forgot to add compression is JDM 10.6
Old Jul 1, 2007 | 07:20 PM
HybridBB6's Avatar
Default Re: Head Gasket Help (HybridBB6)
Anybody?
Old Jul 2, 2007 | 02:32 PM
HybridBB6's Avatar
Can anybody help me out with this?
Old Jul 2, 2007 | 06:23 PM
Missing Gears's Avatar
first of all cometic will make any size gasket you want.
if your trying to get it back close to stock go w/ a .050
if your trying to lower the compression more than it was stock (for the boost) then go w/ a thicker gasket like the .070 you mentioned. that is a thick gasket though.
if its just a stock bottom end you will be fine going back close to stock as long as your not running alot of boost.
Old Jul 3, 2007 | 06:15 AM
preludestud11's Avatar
Default Re: Head Gasket Help (Missing Gears)
i would also suggest some arp head studs.
Old Jul 3, 2007 | 08:59 AM
HybridBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">first of all cometic will make any size gasket you want.
if its just a stock bottom end you will be fine going back close to stock as long as your not running alot of boost.</TD></TR></TABLE>
Thanks.
byohnd
Nov 14, 2005 08:07 AM
CoreyR
Sep 22, 2004 11:02 PM
shawn_crx
Dec 23, 2003 05:31 PM
