F22B1 and H23A1
ok Im getting ready to put the head on the block and I just wanted to make sure before I put the head on if I have to plug the hole on the F22 block for V-TEC, I looked at the H23 block and there is a small plug in it and I want to make dure it will not affect anything, thanks.
ok, Im having problems with the timing belt. Im using the h23 timing belt, tensioner, crank gear, and a f22 non-vtec water pump. The belt is to loose, and I cant get it to tighten up any further. Any help?
mitch_88
Sep 12, 2003 09:34 AM
block, civic, f22b1, h23a1, h23a1partsforf22b1, h2b, head, performance, small, swap, transmission, waterpumps
