200hp lsvtec....suggestions
Old Jul 1, 2007 | 07:34 AM
lsvtec2000's Avatar
Default 200hp lsvtec....suggestions
whats going on everyone..im tring to build a 200hp lsvtec..and i need some help..this is what i have so far
b16 head(full port and polish)
b16 valves
skunk 2(springs and retainers)
skunk 2 stage 2 cams
b16 intake manifold
b18b block(bored .20)
all new bearings
ls crank
gsr(oil and water pump)
12lb act flywheel
act clutch(stage 1)
ls transmission
2.25 exhaust
some cheap *** headers
vfac controller
Old Jul 1, 2007 | 08:16 AM
Jay_Sensing's Avatar
What pistons are you planning to use?
A 2.25 exhaust and cheap *** header will kill the power you are wanting to make.
Old Jul 1, 2007 | 08:19 AM
lunatics209's Avatar
Default Re: 200hp lsvtec....suggestions (lsvtec2000)
throw your b16 manifold away. get at least an itr or skunk2 pro series. as for throttle body there are alot out there but if you want good and cheap i'd say professional products 65 or 68mm. p30 pistons or p73. i see a header on ebay right now they claim its made by hytech. 400 shipped. if not then get pro fab. now im pretty sure you can break 200 with that.
Old Jul 1, 2007 | 09:17 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec2000 &raquo;</TD></TR><TR><TD CLASS="quote">
vfac controller</TD></TR></TABLE>
Bad idea, get a chipped/socketed obd1 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">What pistons are you planning to use?
A 2.25 exhaust and cheap *** header will kill the power you are wanting to make.</TD></TR></TABLE>
+2
Old Jul 1, 2007 | 09:42 AM
94typeR's Avatar
i dont think you know whats youre doing.
do more homework junior
Old Jul 1, 2007 | 09:57 AM
Default Re: (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you know whats youre doing.
do more homework junior</TD></TR></TABLE>
No need to be rude about it, he is asking for suggestions.
Old Jul 1, 2007 | 04:32 PM
lsvtec2000's Avatar
running p28 chipped ecu
and b16 pistons
Old Jul 1, 2007 | 05:31 PM
reactiondc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec2000 &raquo;</TD></TR><TR><TD CLASS="quote">whats going on everyone..im tring to build a 200hp lsvtec..and i need some help..this is what i have so far
b16 valves
b16 intake manifold(id look into a s2 pro series or performer x)
all new bearings
ls crank
12lb act flywheel
act clutch(stage 1)
ls transmission(worst b series trans ever imho)
2.25 exhaust
(big na power and cheap exhaust components dont go hand in hand)
vfac controller(get a custom tune)</TD></TR></TABLE>i highlighted the things id change on your setup if i was you
Old Jul 1, 2007 | 06:19 PM
TheBetterSol's Avatar
Default Re: 200hp lsvtec....suggestions (reactiondc2)
i just got done getting my ls/vtec motor fully built, sleaved, 85mm bore, 12.1 comp pistons, ITR tranny, S200 hondata, Skunk2 pro1 cams and S2 pro cam gears, 1mm over sized intake valves, Crower rods ......and the list gose on i put down 198 hp and 157 tq, the only thing im lacking is a better header and a bigger TB. trust me its not that easy to make 200 hp out of a lsvtec, i do have a spare ITR intake mani i can part with for a good deal if your interested. but best of luck to you and your build.
goldenhatch13
Oct 23, 2008 10:48 AM
lshondaeg
11
Jun 5, 2008 01:36 PM
boostedcivicsir
Oct 28, 2004 03:39 PM
boosted B18B
May 23, 2004 09:18 PM
kunfusoul
Apr 24, 2002 11:03 AM
