Hydro and Cable clutch compatability
Old Jul 1, 2007 | 07:03 AM
fortymcpants's Avatar
Default Hydro and Cable clutch compatability
I just bought a si hatch, so im taking the b18c out of my crx and putting it n the si.
Now I dont want to use the cable tranny i have, so I am going to buy a hydro, but I love my clutch and want to reuse it. My question is can I use my clutch on a hydro tranny. I read in some old posts that the cable trannys have a diff. size input shaft but if thats true, how would it mate with my 0bd2 b18c.
thanks for any help
Old Jul 1, 2007 | 07:06 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Hydro and Cable clutch compatability (fortymcpants)
it will work
Old Jul 1, 2007 | 07:20 AM
97Ej6mike's Avatar
yes, you can use it again.
Old Jul 1, 2007 | 08:55 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortymcpants &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a si hatch, so im taking the b18c out of my crx and putting it n the si.
Now I dont want to use the cable tranny i have, so I am going to buy a hydro, but I love my clutch and want to reuse it. My question is can I use my clutch on a hydro tranny.</TD></TR></TABLE>
It depends on which cable transmission you're currently using. What vehicle did you source it from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I read in some old posts that the cable trannys have a diff. size input shaft but if thats true, how would it mate with my 0bd2 b18c.</TD></TR></TABLE>
Because the transmission input shaft doesn't mate with the engine - it mates with the clutch friction disc. The friction disc is sandwiched in between the pressure plate and the flywheel, both of which are bolted to the engine.
Old Jul 1, 2007 | 09:10 AM
DCboosted95's Avatar
Default Re: Hydro and Cable clutch compatability (Targa250R)
There are 2 different types of input shafts on cable b series trannys. the cable one in a 90-91 integra, or obd0, have a couple of teeth difference on the input shaft compared to the 92-93 integra, or obd1, cable trannys. I believe that the obd1 cable and hydro trannys have the same input shaft, but if not, just buy another clutch disc for the hydro tranny, and you can still use the pressure plate and flywheel that you allready have.
95civiccpdx
Jul 8, 2007 04:56 PM
DSRxSALSA
May 21, 2007 07:58 PM
synner
Aug 6, 2006 12:09 PM
chulopilong
Feb 14, 2003 04:37 AM
