cold air intake vs short ram
I have an H22a1 and I want to know which will give me better gains. The Short ram of cold air. Any suggestions on switch will give me better gains & risk involved for the cold air intake. I know cold air has a common hydrolock issue. Is there really any difference in performance. Thx I checked the FAQ and searched didnt find anything.
Modified by jdmludeaz at 6:52 AM 7/1/2007
A short ram intake will give you better throttle response, since the air doesn't travel as far through the tube, so it will give you better gains in the lower end.
A cold air intake will give you better top end gains.
The only risk in a cold air intake is hydrolock, but if you get the AEM bypass valve, that solves the problem.
if you hydrolock your motor by sucking in water through the intake, then you have no buissness behind the wheel of an automobile in the first place because you clearly have no common sense.
go w/ the cold air, and stay away from deep water, streams, lakes, rivers, and ponds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtec »</TD></TR><TR><TD CLASS="quote">A short ram intake will give you better throttle response, since the air doesn't travel as far through the tube, so it will give you better gains in the lower end.
The only risk in a cold air intake is hydrolock, but if you get the AEM bypass valve, that solves the problem.</TD></TR></TABLE>
you got it totally backasswards
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmludeaz »</TD></TR><TR><TD CLASS="quote">Thx I checked the FAQ and searched didnt find anything.
Modified by jdmludeaz at 6:52 AM 7/1/2007</TD></TR></TABLE>
how can you find nothing, this has been covered over, and over, and over again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">
Explain???
</TD></TR></TABLE>Explain???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtec »</TD></TR><TR><TD CLASS="quote">A short ram intake will give you better throttle response, since the air doesn't travel as far through the tube, so it will give you better gains in the lower end.</TD></TR></TABLE>
Well, for one the air is already inside the tube regardless of how long it is. Throttle response is about the same...you can stick the filter right on the throttle body and it doesn't make much difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">.you can stick the filter right on the throttle body and it doesn't make much difference.</TD></TR></TABLE>
REALLY?!
REALLY?!
The length of the tube does affect throttle response. It's the same deal behind the length of the runners of the intake manifold.
Short ram really doesn't offer any gains because it's drawing hot air from the engine compartment.
You say that, but the H22 in my track car made better mid and peak WHP with an AEM CAI compared to an AEM V2. Same day, same dyno, about 10 minutes apart. No tuning was done for the V2, though, just the CAI (NepTune).
IMO, it's difficult to say which one is "better" as all the parts work together, so what works good on one engine might not work so good on another.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">you got it totally backasswards
Has anyone actually datalogged the IAT with a CAI and SRI? I'd do it, but I don't have an SRI to install...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">The length of the tube does affect throttle response. It's the same deal behind the length of the runners of the intake manifold.
Short ram really doesn't offer any gains because it's drawing hot air from the engine compartment. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">
REALLY?!
Yeah, I drove to Austin once with just a filter on the TB and I didn't notice much...maybe a bit less power all over the RPM range cuz of the heat, but that was about it. Just a butt-dyno though
REALLY?!
But it allows more air than a stock filter would, so it does offer some gains over stock.
The runners on the IM are after the throttle body, which is a bit different that a tube on the other side of the TB. Plus the runners go directly into the cylinder head so things like diameter, length, surface texture make a lot more difference. You can tune the runners so that the pulses from the valves bounce off the plenum and come back at the valves when they open and push more air into the chamber.
Intake tubes can't do that.
shutuprichard551
14
Oct 29, 2008 05:33 AM
ILS_09
Aug 14, 2008 03:32 PM
bowhunter
May 26, 2003 04:41 PM
