gsr sk2 trouble
i have a 94 swap gsr.....recently i put in sk2 stg1 shaft, no knocking sound after installment.....everything works fine no trouble.....got UO pulley, fuel rail, stg 3 clutch, sk2 stg1 shaft....the cars weaker with the shaft, does it mean i need valve springs and a chipped ecu....with the stock shaft its more powerfull....also used timing gun to time it...any suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie »</TD></TR><TR><TD CLASS="quote">valve springs arent necessary as long as you keep the stock redline, but be sure to get it tuned.</TD></TR></TABLE>
might want to also consider an IM.
Junkyard2000
25
Sep 16, 2005 04:33 PM
