Hubcentric Dimensions - Which is correct?
Old Jun 30, 2007 | 07:19 PM
Mohsin's Avatar
Default Hubcentric Dimensions - Which is correct?
hello all,
i've attached a pic of my wheel but unsure as to which is the Outer Diameter. The red line is 67mm and the Blue line is 73mm. Which is the correct OD?
Wheel - Yokohama Advan Supers 4x100 (EG6 SiR)
Thank You.
Re
Modified by Mohsin at 1:51 PM 7/1/2007
Old Jun 30, 2007 | 09:23 PM
r.wright's Avatar
Default Re: Hubcentric Dimensions - Which is correct? (Mohsin)
the majority of hubcentric rings are made with the outer diameter being 73mm and the inner part being 56.1mm to fit your civic..
http://cgi.ebay.com/ebaymotors...QrdZ1
these are what you need
Old Jul 1, 2007 | 04:40 AM
Mohsin's Avatar
Default Re: Hubcentric Dimensions - Which is correct? (Opossum Jenkins)
so is my OD 67mm or 73? The rings are avail in both sizes.
Old Jul 2, 2007 | 04:32 AM
r.wright's Avatar
73mm
from your 'imaginary' blue line and and 'out' towards the back top surface of your mounting pad(behind the rim,backside) is where the hub centric ring will sit snug and then the inner part of the ring is where your stock hub will fit into which is 56.1 like it says in the ebay link i posted
neoc03
Nov 2, 2009 07:54 AM
TylerC161
Oct 10, 2007 03:31 PM
rOby
Oct 15, 2002 10:56 PM
b18bvudoo
Jan 2, 2002 05:51 PM
