Gsr/EG bubble back
I did a gsr swap into my 93 bubble back all went ok but i keep getting codes 14 and 20 (idle air control and ellectric load detector) and i also have no vtec. I also wanted to know if anyone could show me a pic or tell me where the (IAB) intake air bypass control solenoid valve is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote">iab is under the intake manifold, strapped up with a metal band. it's black and there is a plug on it.
LOL. I'm pretty sure those pictures are from back in the day when Katman didn't know nearly as much as he does now. The "purge solenoid valve" isn't what its labeled as. Thats the vac diaphram that opens/shuts the IAB valves. A purge solenoid valve has to do with emissions and the charcoal canister. The "IAB solenoid" is also mislabeled. The black box is nothing more then a vacuum storage tank. The actual valve is where the "plug" is labeled in his picture. Just thought I would clear that up.
</TD></TR></TABLE>LOL. I'm pretty sure those pictures are from back in the day when Katman didn't know nearly as much as he does now. The "purge solenoid valve" isn't what its labeled as. Thats the vac diaphram that opens/shuts the IAB valves. A purge solenoid valve has to do with emissions and the charcoal canister. The "IAB solenoid" is also mislabeled. The black box is nothing more then a vacuum storage tank. The actual valve is where the "plug" is labeled in his picture. Just thought I would clear that up.
transpar_nt
Dec 4, 2005 03:18 PM
