air/fuel ratio guage install on b16
Old Jun 30, 2007 | 06:48 PM
lovey408's Avatar
Default air/fuel ratio guage install on b16
im just bout to finish puttin my motor back in after rebuildin the block and boring it to 84mm. i talked to my tuner and he siad u can start it and if it doesnt run lean u can break in the motor b4 u get it tuned.. so i need to find out how to install the guage properly. i had it b4 but it wasnt hooked up right or my sensor was bad so i got a new sensor but dnt knw hwo to install it..... there are 4 wires on the sensor.. does anyone know how to do this? im sure others have done it on there b16's
Old Jun 30, 2007 | 07:01 PM
numbnuts22715's Avatar
I believe team integra has a howto on it.. although your car isnt an integra, I think it should help you out as long as you can find your own ecu pinouts.
Old Jun 30, 2007 | 10:31 PM
dpetro1's Avatar
Default Re: air/fuel ratio guage install on b16 (lovey408)
hopefully you are talking about a wideband gauge. if not i wouldnt risk my fresh build on a standard narrowband. there are plenty of write-ups on the install check out the FAQ and there should be an ECU pinout thread as well.
Old Jul 1, 2007 | 04:02 AM
JSPECSIR's Avatar
Default Re: air/fuel ratio guage install on b16 (dpetro1)
http://www.plxdevices.com
Old Jul 1, 2007 | 07:20 AM
1fastEK9's Avatar
Default Re: air/fuel ratio guage install on b16 (JSPECSIR)
if you are conecting it 2 the sensor is going 2 be the green wire
Old Jul 1, 2007 | 09:05 AM
lovey408's Avatar
Default Re: air/fuel ratio guage install on b16 (1fastEK9)
yeah it connects to the actual sensor. there are 2 wires. so wat one goes to the green and wat ones goes to the other one?
sins
Sep 28, 2009 10:00 AM
JDM R Cooker
Mar 12, 2007 04:11 PM
GocosblucivicSi
Jul 9, 2006 06:40 PM
poser1kenobe
Jun 24, 2004 07:55 PM
shift6th
Feb 10, 2004 04:52 PM
