110000 miles
Old Jun 30, 2007 | 05:38 PM
d1honda's Avatar
Default 110000 miles
my 98 Civic got 110000miles now.
what parts should be check and replaced?
thanks
Old Jun 30, 2007 | 05:46 PM
oneslowstd's Avatar
Default Re: 110000 miles (d1honda)
The most important thing to replace is your timming belt and water pump, but you should also consider the spark plugs, and maybe wires.
Old Jun 30, 2007 | 06:06 PM
Bulli Kid's Avatar
Default Re: 110000 miles (oneslowstd)
oil pump! maybe.
Old Jun 30, 2007 | 06:28 PM
Jhonny Ricer's Avatar
Default Re: 110000 miles (Bulli Kid)
Id check
Clutch
Brakes
All brake lines fuel lines for oxidation
hoses for dry rot
Calipers to make sure they are working properly
Rotors
shocks
battery
I would replace
Oil
Tranny fluid
Coolant fluid
Brake fluid
Clutch fluid
air filter
oil filter
head gasket
spark plugs
plug wires
timing belt
alternator belt
power steering belt if you have it
I would only do this because after I bought mine I failed to check and less than 30000 miles later problems started occuring and my motor blew so now Im paying for it...
Modified by Jhonny Ricer at 9:36 PM 6/30/2007
Old Jun 30, 2007 | 06:29 PM
sicones's Avatar
Default Re: 110000 miles (Jhonny Ricer)
you don't change an oil pump and headgasket if it's not bad
Old Jun 30, 2007 | 06:32 PM
EG2Driver's Avatar
Default Re: 110000 miles (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you don't change an oil pump and headgasket if it's not bad </TD></TR></TABLE>
You got that right. If it ain't broke don't fix it, but this doesn't apply to timing belts. Fix it before it breaks!
Old Jun 30, 2007 | 06:33 PM
egsleepercivic's Avatar
x2
Old Jun 30, 2007 | 07:34 PM
Default Re: 110000 miles (egsleepercivic)
I would rather have replaced the headgasket than have the motor overheat like it did I said that was just me and id rather replace things and not have to worry about it for the next 100,000 miles rather than be going down the road on my way to NC and have my headgasket blow
Old Jun 30, 2007 | 07:41 PM
hondamark35's Avatar
that's dumb. headgaskets don't just blow cuz you have over 100k on the motor. we aren't dealing with an old pontiac it's a honda, fresh oil and following "recommended" maintainence and you can run these things forever.
the biggest thing at 110000 is timing belt package. 'sposed to be done at 105k. have a good honda specialist or dealership catch you up on maintainence and drive it like a mildly sane person
Old Jun 30, 2007 | 07:43 PM
slowcivic2k's Avatar
x3
Oil pumps and headgaskets are not maintainence items... on honda's anyways....
If it is sealing good no need to worry about it. This would be the time where I would do a compression test to see how well my engine is still performing, and note any possible performance problems before I go sticking more money into maintaining it. If the belt has never been replaced, I highly suggest replacing that, the tensioner, and the water pump.
Mass replacement of parts will only lead to frustrations when you cant even get the car to where it was before, because too many things were changed to note the cause of it in the first place.
Old Jun 30, 2007 | 07:59 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: 110000 miles (slowcivic2k)
hehe I have a d15 running strong on factory timing belt and water pump @ 245,000 miles. only thing ever done to the whole car is 1 clutch, 1 tune-up, 3 sets of tires, a couple of air filters, and regular 6k oil changes... Take that, PONTIAC!
Old Jun 30, 2007 | 08:31 PM
Default Re: 110000 miles (oneludesol)
Sorry bud my head gasket did "just blow" 200 miles from my house so yea I kind of wish I had changed. This was also on oil change every 3k new air fileter every two months and a tune up every 6 months...
Old Jun 30, 2007 | 08:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">Sorry bud my head gasket did "just blow" 200 miles from my house so yea I kind of wish I had changed. This was also on oil change every 3k new air fileter every two months and a tune up every 6 months...
Headgaskets don't just fail for no reason.....
Old Jun 30, 2007 | 08:54 PM
DecentCivicZ6's Avatar
B A N N E D
pssshhh,Tell that to me and my friends. friend of mine put 9;1 pistons h beam rods, the usual upgrades for a 400whp turbo B series...it lasted him about 3days just breaking the engine in before dyno tune....3rd day it locked up...Oil pump jusst stopped working out of the blue...haha...so...i wouldnt say they dont need changing...timing Belt, and Oil pump are cheap...and if they break...what happens is not cheap...lol
Old Jun 30, 2007 | 08:58 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: 110000 miles (DecentCivicZ6)
whoa, i think the topic leaned more toward a stock engine still in car, not a freshly rebuilt turbo setup that has already been ripped apart.
Old Jun 30, 2007 | 09:10 PM
B A N N E D
ok? its still an oil pump can that can out anytime isnt it? and will cause damage on a turbo built or stock car. Its an easy replacement. and cheap.
Old Jun 30, 2007 | 09:13 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (DecentCivicZ6)
oil pump and head gasket are in no way regular scheduled maintenance items... end of story. argue all you want. by your rational, what if that same day his car got hit by an expedition and totaled. Is SUV resistant paint regular maintenance too? and, brand new oil pumps can fail too.
Old Jun 30, 2007 | 09:16 PM
B A N N E D
who the expletive said regular scheduled maintenance items??? im pretty sure home boy said he has 110kmiles on car....What should he check. Im telling him real people things. its a $100 part. easy to install...keep from paying $1000+. get off my ***** go argue somwhere else. **** man, sorry for trying to save some one money..lol..gonna seriously argue cause we said oil pump..lol im done
Old Jun 30, 2007 | 09:23 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
hmm, what should I check and replace at 110000 miles sounds like scheduled maintenance to me, not im building a 400whp turbo b16 what should I replace... hehe douche, I manage a repair shop... If I even merely suggested to customer to replace a head gasket and oil pump at 110000 simply for precautionary measures, I would be branded a crook and burned alive at the stake.
Old Jun 30, 2007 | 09:30 PM
B A N N E D
lol, i had to reply to that........ that is funnny about being branded a crook...lol thats how lacks is in lynchburg..lol told me $600 in parts to pass inspection..drive 200yards away. $15 sticker. done. lol... but yeah im just saying...i dunno if hes BONE STOCK..or has some mods..Id replace it. im gonna replace mine maybe everytime i have to pull mine down since that happened to my 2 friends. $100 just isnt nothing compared to the time and money if it did break. ha
Old Jun 30, 2007 | 09:33 PM
B A N N E D
oh BTW oneludesol...is that the ******* shocker icon??? lol 2 in the pink, 1 in the stink
Old Jun 30, 2007 | 09:34 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
lol, i mean it too, real branding iron and real hay fire with me in the middle!
Old Jun 30, 2007 | 09:35 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (oneludesol)
fo sheezy, and with real kung fu action as well! 2 in the pink 1 in the stink, 2 in the bush 1 in the touche! hehe
Old Jun 30, 2007 | 09:38 PM
B A N N E D
hahaha....i learned about that my first time at age 14 in myrtle beach...lol...great times.
Old Jun 30, 2007 | 09:41 PM
I never said that a head gasket is scheduled maitnance but I like to take precautions so from now on when ever my vehicle whatever it may be hits ts next 100000 miles ill be changing the headgasket mine blew and i dont know why i was cruising in 5th at like 70 so its not like i was racing the engine or anything...
