Need help on timing belt
Old Jun 30, 2007 | 05:34 PM
quik sol's Avatar
Default Need help on timing belt
I am changing my timing belt, I set the crank to TDC and same with the cam gears at TDC. I put the belt on, and try running it around. I do full rotations on the crank and then my cams are 1 tooth off. What could I be missing? I have a factory Helms manual for my car but it doesn't go into any great detail on tension, but I just push it up as hard as I can and tighten, but their is still so much play in the belt on the front side I can never get rid of.
1994 Honda Del Sol B16a3
Old Jun 30, 2007 | 06:27 PM
Syndacate's Avatar
Default Re: Need help on timing belt (quik sol)
You sure it's the right timing belt?
Did you replace the tensioner?
Old Jun 30, 2007 | 06:32 PM
sicones's Avatar
with the crank and cams at TDC:
- loosen the tensioner bolt 180 degrees
- turn the crank 3 teeth counter clock wise
- tighten the tensioner bolt
Old Jun 30, 2007 | 06:38 PM
93baggedcivic's Avatar
but the belts up next to each other make sure its the right belt.
Old Jul 1, 2007 | 01:26 AM
quik sol's Avatar
Default Re: Need help on timing belt (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">with the crank and cams at TDC:
- tighten the tensioner bolt</TD></TR></TABLE>
this was it. Thanks for all the help, got it all on now and tight. So now all I got is the alternator belt and p/s belt and I am set.
Shinny
Jun 6, 2018 12:13 PM
ryanevansoh
Apr 22, 2009 08:51 PM
turboedsupe
Sep 19, 2008 04:32 PM
stevescivic
Sep 9, 2005 02:31 AM
vtec69
Jan 16, 2003 10:28 AM
