How do you get water out of the engine cylinders?
I was car washing my engine (dum,, dum) and notice I had gotten water in the engine cylinder via spark plugs. How do I get the water out without using fancy suction devises?? mcv57@comcast.net
u didnt have ur sparkplug wires out while washing it did you?
thaaaats a nono
id say just let it sit for a while....or take the distrib off, and turn it over a couple times
thaaaats a nono
let me verify how dumb you are, so you were spraying water on your engine with the spark plugs and wires out of the engine
real smart
spray WD40 down the cylinders
real smart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Removes all the plugs and crank the motor. Then just let it dry.</TD></TR></TABLE>
Do it that way, just like old faithful....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">
spray WD40 down the cylinders</TD></TR></TABLE>
WD40 won't do squat if the cylinders have more than a thin film of water.
If the plugs were still in the head, use some compressed air to blow the water out, or just let it sit and it'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Changing the oil wouldn't work?</TD></TR></TABLE>
no
no
ya, the easiest way is to take the plugs out and crank the motor over a few times to shoot the water out. Then let it sit over night with the plugs still out, and then try to start it again in the morning, or later in the day, and that should work. same thing happened to me when I had my cold water intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951BRO »</TD></TR><TR><TD CLASS="quote">
no</TD></TR></TABLE>
[This post was interpreted as dis-information and removed by a moderator.]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake »</TD></TR><TR><TD CLASS="quote">if it hasent fell into the block roll up a paper towel stick it down there, let it soak up the water then take it out.</TD></TR></TABLE>
Good point, if the plugs are still in, then do that.
If that's true, then once you soak up what's collected at the plugs. Anything beyond that will just be minute amounts of water.
