VSS issues, not the normal problems
Old Jun 30, 2007 | 01:44 PM
RCautoworks's Avatar
Default VSS issues, not the normal problems
Here it goes, I have a 94 eg and its throwing a code 17 which is vss, and the speedometer does not work. I checked the wiring and diagrams and with the results I got, it said replace ecu, but thats very unlikely the cause so I just pretty much ignored that. I was getting voltage when spinning the wheels, but noticed resistance was very high on one of the wires, therefore I hardwired it.
So anyways I swapped in an extra vss I had, and still code 17 and no speedometer. So I decided to hard wire it, I know the black is a groud, yellow and white is b10, then the other yellow is constant 5v correct ? Does anyone know where exactly that goes ?
Anyways I hardwired the vss, and now vtec does work, but the cluster still does not work, and I'm throwing a code 17, and this is where I'm a little stuck. Any advice ?
miniproblems
Jul 22, 2016 10:23 AM
thecorey
Oct 13, 2008 08:06 PM
RCautoworks
13
Jun 30, 2007 07:19 PM
dthug
Aug 17, 2006 11:29 AM
92integraVTECgsr
Oct 25, 2005 11:28 AM
