what is this????
Old Jun 30, 2007 | 11:51 AM
basshead88's Avatar
Default d16y8 fucked..help pleaseeee
i was just wodering what this was
it was unpluged the day my problem started and i pluged it back in and it seemed to be better for a while..but then it came back like a week later..could it have anything to do with this? ----> https://honda-tech.com/zerothread?id=2028078
Modified by basshead88 at 1:12 PM 6/30/2007
Old Jun 30, 2007 | 11:54 AM
kaiba's Avatar
Default Re: what is this???? (basshead88)
Is it that the plug for the vtec solinoid????
Old Jun 30, 2007 | 11:57 AM
basshead88's Avatar
Default Re: what is this???? (kaiba)
sorry for the shitty pic, its from my phone..but uhh it is bolted onto the dizzy cap. i was just wondering cuz ive changed the cap/rotor, plugs, wires and still cant figure this **** out...idk
Old Jun 30, 2007 | 11:58 AM
95ProjectEJ1's Avatar
Im thinking that it was maybe something from the dizzy giving the problems listed in the thread he posted. Un unplugged solenoid wouldn't cause a bouncy idle or any of the other problems he listed right?
Old Jun 30, 2007 | 12:05 PM
basshead88's Avatar
Default Re: what is this???? (95ProjectEJ1)
well i guess i kinda described it wrong so ill try again..when i start the car cold everything seems to be running normal..if i drive it across town or let it idle for 5-10 min and then turn it off...then when i start it back up it is hard to start..after i get it started back up it idles really low..like 4-5 hundred rpm...then ill rev it up and its seems to idle at the right rpms and the it will like miss...and every now and then the rpms will die down and be at almost 0 rpm and then it will sound like it wants to die..then it will sorta catch itself and the rpms will go back up...it will do this a few times and eventually die.
Old Jun 30, 2007 | 12:08 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The connector plug in the picture is for the VTEC solenoid valve...; however, the problems you have may be due to something else.
Old Jun 30, 2007 | 12:19 PM
basshead88's Avatar
Default Re: (tech8)
anybody got any suggestions on what i could do to try and fix this?
Old Jun 30, 2007 | 01:43 PM
Default Re: (basshead88)
plug that back in first, and when was the last time you did a cap/rotor, plugs, wires change?
Old Jun 30, 2007 | 02:40 PM
slowcivic2k's Avatar
Default Re: d16y8 fucked..help pleaseeee (basshead88)
Did you perform any of the trouble shooting I gave you in the last thread you started?
Old Jun 30, 2007 | 03:30 PM
basshead88's Avatar
Default Re: (95ProjectEJ1)
did all of that before making this thread
Old Jun 30, 2007 | 03:31 PM
basshead88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">plug that back in first, and when was the last time you did a cap/rotor, plugs, wires change? </TD></TR></TABLE>
basshead88's Avatar
Default Re: d16y8 fucked..help pleaseeee (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Did you perform any of the trouble shooting I gave you in the last thread you started?</TD></TR></TABLE>
yea i puled off the iacv and cleaned it out...still no change
emooheo
Aug 9, 2007 03:35 PM
JDM-EJ698
Nov 9, 2006 11:05 AM
x_tc-Dae
Oct 7, 2004 01:07 PM
typeR936
Sep 20, 2004 07:37 PM
EARLdaSQUIRREL
Apr 30, 2004 08:32 AM
