bronze valve guides
bad things happened to my motor and i ended up with 2 broken valves, which in turn broke the valve guides. and two bent valves which make 2 other valve guides questionable.
since i'm having my head repaired are bronze valve guides worth the money? or should i just have my machinest put in factory guides.
http://inlinefour.com/bronvalguid.html these are the guides in question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neofreak »</TD></TR><TR><TD CLASS="quote">bad things happened to my motor and i ended up with 2 broken valves, which in turn broke the valve guides. and two bent valves which make 2 other valve guides questionable.
http://inlinefour.com/bronvalguid.html these are the guides in question</TD></TR></TABLE>
if you had searched!
you would have found plenty of information on this and just recently another thread about this popped up should answer everything there!
https://honda-tech.com/zerothread?id=2025077
airmaxbri
Feb 21, 2010 08:47 PM
