everybody with f/i please chime in.(survey)
if you are boosted
do you have an oil leak or do you not have an oil leak?
i have basically redone everything on my setup and all i get is more and more leakage. but maybe that is what happens if you boost your honda....idk just makeing sure its not me.
also what is a good sealer to avoid oil leaks, i heard rtv gray is good but is there any better sealents? i have teflon on all my fittings and they are tighter than a 10year olds vagina. i just dont get it.
right from the turbo inlet and outlet, where both gaskets are. just fixed all of them the other day. and i just had a gasket crack on me. and to get to the gasket, atleast for how my setup is and how the turbo is clocked i have to take all of it out(manifold turbo, WG, oil lines) and then fix the 2sec fix and then reassemble everything again. i guess i learn how to put turbo kits on car's faster.
hopefully this gasket doesnt break, i sealed the gasket in rtv gray, we will see what happens.
