Honda S2000 Honda S2000
Help! s2000 manual transmission fault?!?!
Old Jun 30, 2007 | 02:16 AM
Mashka's Avatar
Default Help! s2000 manual transmission fault?!?!
i was going up the road with second gear,suddenly i heard a strange sound, i stopped the car and and i tryed shifting in all gears and there was a sound in each gear i shifted, if i press clutch,then there's no sound,if i release clutch there's even sound in neutral. what should be the problem? did anyone experianced it?
Old Jun 30, 2007 | 07:21 AM
b20integrapower's Avatar
Default Re: Help! s2000 manual transmission fault?!?! (Mashka)
Probably the throw out bearing. Mine is whining right now too.
Old Jun 30, 2007 | 01:49 PM
BlueSi2k's Avatar
Default Re: Help! s2000 manual transmission fault?!?! (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">Probably the throw out bearing. Mine is whining right now too.</TD></TR></TABLE>
tob will usually make noise when the clutch is in. He's saying it stops when the clutch is in. What kind of sound is it?
Old Jun 30, 2007 | 05:30 PM
Default Re: Help! s2000 manual transmission fault?!?! (BlueSi2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">
tob will usually make noise when the clutch is in. He's saying it stops when the clutch is in. What kind of sound is it?</TD></TR></TABLE>
Umm..it will make noise with the clutch NOT depressed. It stops when the clutch IS depressed
Old Jun 30, 2007 | 09:53 PM
BlueSi2k's Avatar
Umm..it will make noise with the clutch NOT depressed. It stops when the clutch IS depressed</TD></TR></TABLE>
umm when the clutch is not depressed the bearing is not in use so it wouldn't make noise. When you press the clutch the bearing slides and contacts the fingers of the pressure plate which spin the bearing. If the bearing is screwed up this is when you'll hear it.
Old Jun 30, 2007 | 11:02 PM
umm when the clutch is not depressed the bearing is not in use so it wouldn't make noise. When you press the clutch the bearing slides and contacts the fingers of the pressure plate which spin the bearing. If the bearing is screwed up this is when you'll hear it.</TD></TR></TABLE>
Okay...you win. I'm not going to argue.
Old Jul 3, 2007 | 07:55 AM
Mashka's Avatar
where i am buy used, but good transmission??
anyone help me please...
in my country not a honda dealer.. & service honda center... but mechanics does not have a instruments to repair my transmission...
Old Jul 3, 2007 | 08:21 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashka &raquo;</TD></TR><TR><TD CLASS="quote">where i am buy used, but good transmission??
</TD></TR></TABLE>what country are you in? Check S2ki buddy there are some transmissions on there for sale.
Old Jul 3, 2007 | 08:55 AM
Mashka's Avatar
Default Re: Help! s2000 manual transmission fault?!?! (JDM knowledge)
Georgia(Former USSR), Tbilisi
Newer the Black sea
kenzo42
Oct 14, 2008 03:11 AM
defcon86nwh
Honda S2000
May 8, 2007 06:03 AM
mm99lude
Aug 19, 2006 07:30 AM
EK79
Apr 25, 2006 12:19 PM
2qwik2nv
Jul 1, 2003 04:50 AM
