need help
Old Jun 29, 2007 | 08:34 PM
2000siturboR's Avatar
Default need help
ok this might sound stupid and all but i have a 00 civic si turbo running six punds of boost with a manifold but to the point my manifold gets that hot that the gasket rubber piece on the dip stick get so hot that oil shoots up on to my hood and motor any ideas how to fix it or some other dip stick that wont make it come loose
Old Jun 29, 2007 | 09:38 PM
akunamatta's Avatar
* B A N N E D *
u could have excessive crankcase pressure, i would start by checking your PCV valve chances are you need a replacement.
one of these...
Old Jun 29, 2007 | 09:58 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (akunamatta)
Somebody did a half-*** job on their oil return lines.
Old Jun 29, 2007 | 10:02 PM
akunamatta's Avatar
* B A N N E D *
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Somebody did a half-*** job on their oil return lines.
do u think that could be the problem? i was thinking pcv...
Old Jun 29, 2007 | 10:08 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta &raquo;</TD></TR><TR><TD CLASS="quote">
do u think that could be the problem? i was thinking pcv...</TD></TR></TABLE>
Could be anything that has to do with oil return and oil exchange.
Difficult to diagnose without looking at the car.
Old Jun 30, 2007 | 02:57 PM
slowcivic2k's Avatar
Boosted motors have more blowby gasses resulting in air flow from the crankcase in excess of what the PCV can handle. Under boost the manifold pressure will slam the PCV closed, leaving it no where else to go, and if the valve is faulty and doesn't seal, youll be sending boost into the crankcase, which really sucks...
A few people around here cut holes in the front of the valve cover and install a ribbed connector for a length of hose to a catch can. It's not uncommon to have to drill 2 or 3 new vents in the valve cover to allow the crankcase pressure to vent. That is also the reason your dipstick come out of the tube.
Look at big diesel trucks, they use locking dipsticks for a reason....
dc2greddy
Jul 10, 2007 08:29 AM
integra3586
May 14, 2007 02:25 PM
zenon8890
Aug 18, 2006 04:07 PM
Zyepher
Jun 13, 2006 09:53 PM
NA-Cutie
17
Jan 29, 2005 05:04 PM
